Hello just curious if Trinity 2 MX will display temp readings in particular Transmission Temp and Car oil Temp
Thanks in advance for info
Temp Gauges
Re: Temp Gauges
What vehicle?
Engine oil temp is not normally something the PCM monitors...
Re: Temp Gauges
And on GM vehicles, the tranny stuff is not and can not be monitored at all.. only the engine parameters/PID's can be monitored, nothing for the transmission..
Again, I'm talking about 2007+ GM vehicles... it may or may not be the same for Ford/Dodge/Chrysler/Jeep...
Re: Temp Gauges
A 2008 Pontiac GXP had a onboard info center that included transmission temperature. I guess that was through a temp sensor unable to be read by the ECM? Just curious. Actually all the LS4 GXPs had that.
Re: Temp Gauges
Trans temp is different. PCM often monitors that for various reasons, and the PID can be sent from the TCM or PCM in different applications.Kytprice wrote:A 2008 Pontiac GXP had a onboard info center that included transmission temperature. I guess that was through a temp sensor unable to be read by the ECM? Just curious. Actually all the LS4 GXPs had that.
Engine oil temp is not often something the pcm is monitoring in all cases.
Re: Temp Gauges
Only interested in Transmission temp. Oil pressure and transfer temp. So unless I'm reading your reply wrong it can be done. If so can you send me a file to apply to my Trinity 2? Heat is what destroys these 4T65-HD transmissions. I have a cooler but would love to keep a eye on it.
Re: Temp Gauges
No, I dont mean to keep confusing things here.
TCM PIDs for GM are not something we can display on our devices at this time.
