Through ignition, WiFi plugged into the computer and WiFi while tuned in my jeep while plugged into it.mikel wrote:OK, we're looking into this issue.
As for the updates, are you doing this on wifi or ignition?
I am not seeing where the current version has been delivered more than once.
T2 issues
DaMonsterMonster
Re: T2 issues
DaMonsterMonster
Re: T2 issues
Any updates? Diablo tune works just fine too.mikel wrote:OK, we're looking into this issue.
Re: T2 issues
Our software team is looking into this still.
DaMonsterMonster
Re: T2 issues
Just updated tuner, still does the same thing. This is getting really annoying that I bought a tuner for $600 that doesn’t work like it should.mikel wrote:Our software team is looking into this still.
Re: T2 issues
there hasnt bee a fix posted just yet, sorry for the delay.
I will post up when it is ready, no need to keep checking.
DaMonsterMonster
Re: T2 issues
Do you guys have any idea as to what could have caused this issue yet? Is there a way to possibly delete the tune files and transfer them back on in case they somehow got corrupted? Also are you guys going to add the ability to disable drl or at least change them to parking lights? Tired of my lights flickering if I dont turn auto off.mikel wrote:there hasnt bee a fix posted just yet, sorry for the delay.
Re: T2 issues
DaMonsterMonster wrote:Tried mpg booster and 87 octane then switched to perf crawl and it’s the only one that it absolutely wont rev up at all with. Tuner still keeps trying to update but keeps installing the same update over and over.mikel wrote:everything in the file looks correct, nothing stands out or is set up improperly.
Are there any codes when this happens? BLEW MY ENGINE 4K miles
Tried any of the other tunes yet?
DaMonsterMonster
Re: T2 issues
Whoa that sucks. I have been running this tuner on the hot tune for over 10k miles. First time I have heard of a serious issue with a diablosport on a jeep. It's usually the superchips that have the issues like bricking the ecu.Christian wrote:Blown engine 4k miles !!!!!
DaMonsterMonster
Re: T2 issues
Also which motor? 3.8 or 3.6?Christian wrote:Blown engine 4k miles !!!!!
Re: T2 issues
there is nothing in these tunes that will cause a motor to fail....
Re: T2 issues
I just got the T2 for my 13 charger. I keep running into the issue that if I load a tune(93&91 octane) msd for some reason doesn't shut off. I have tried to switch it off in the switches section but every time I do the tuner switches to the please wait % screen then freezes up. Any help would be awesome.
DaMonsterMonster
Re: T2 issues
That's what I kind of figured. Just curious on which motor because the 3.8 is notorious for burning oil and wouldn't surprise me if they didnt check their oil. Is there any way you can send me a new tune file for this tuner for the perfect crawl tune and see if mayhe the tune file got messed up in any way?mikel wrote:there is nothing in these tunes that will cause a motor to fail....
