tuner shutting down
This section of the forum is for discussion relating to the T2 tuner/monitor on Ford vehicles.
robi6633
tuner shutting down
Post by robi6633 »
F-150 2015 3.5l eco boost. My tuner shuts down for no apparent reason on a regular basis. I have to stop truck and then restart usually get the gages working again. This happens in all tunes and even when using factory tune.
Re: tuner shutting down
So you can just be driving along and monitoring gauges then it shuts off, or freezes up?
robi6633
Post by robi6633 »
yes it just stops and the only way to start to turn truck off, open door and then restart.
robi6633
Post by robi6633 »
I would say it freezes up because the display is still on just the gauges are not working.
Can you post the contents of the runtime folder from the t2 drive as well as the info.xml file from the t2 drive?
Return to “T2 for Ford”
