Hello,
Very first time posting or logging in and still learning the Predator 2 options but i need some help. I have the Predator 2 platinum and want to get a custom tune built but need a copy of the last tune but cant seem to find it when i plug into the computer and dont see anything in the manual either. Any help is appreciated, thanks.
Copy of last tune and stock tune
Re: Copy of last tune and stock tune
P2 just has a backup file, you'll send that to the tuner to have the custom tune made.
tx_made_tx_razed
Thank you for the reply.
Would you happen to know what folder will I find the backup file in?
VehFiles
UI
DeviceInfo
DB
DataLogs <----------------------------------- The Datalog Folder containing DAQ data logs, formatted for DataViewer
datalog_1.xml <----------------------------------- A DAQ data log XML file for DataViewer
datalog_2.xml <----------------------------------- Another DAQ data log XML file for DataViewer
Config
CustomTunes <----------------------------------- Custom Tunes folder for CMR/DataViewer
Stock <----------------------------------- The Folder containing the Stock (Original) File read from the vehicle
123xxx.frg <----------------------------------- A CMR Tuning file for the Vehicle
456xxxx.frg <----------------------------------- Another CMR Tuning file for the Vehicle
789xxx.frg <----------------------------------- Another CMR Tuning file for the Vehicle
myGauges.dsh <----------------------------------- A Dash Board file used for Data Viewer DAQing
It will be in the folder labeled stock within the custom tune folder on the P2 drive.
UI
DeviceInfo
DB
Config
tx_made_tx_razed
Thanks a bunch Mike! Really appreciate the help!
