predator 2 7202
predator 2 7202
bought a predator 2 for my 2003 silverado 1500 hd i updated it out of the box hooked up to truck and chose the 87 performance tune for 1-2 &2-3 shift points i used diablo value and 3-4 i used stock. on all shift pressure choices i used stock plus 6psi and disabled torque management. i left all other parameters stock. all my shifts are perfect and the extra power is great but now my torque converter locks at 60mph instead of 50mph in overdrive i was curious if this is normal or not i would like it to lock up at 50mph like factory if all possible thank you!
Re: predator 2 7202
i wouldnt expect that to be changed. Can you provide the device serial number?
Re: predator 2 7202
Serial number is 201323295
Re: predator 2 7202
Ive asked someone to verify the tune changes for us.
Re: predator 2 7202
Hi Guys,
I recently installed a K&N cold air intake and I'm wondering if there is any settings that needs to be done on my predator 2 to get more power from it?
I didn't find any option in the tune menu, but I think I saw the cold air intake specs in some place that I cannot recall.
Do you have any advice ?
Re: predator 2 7202
what vehicle is it?Kun wrote:Hi Guys,
Most GMs do not require a tune for a CAI.
Re: predator 2 7202
Hi Mike, thank you for your reply.
An Escalade 2013. So, from what I see in the options menu I only have air intake temp whcih I really don't know how or what can I do with it.
But maybe there is another tun from anotheDiablo that can be used to get nore gain from th cold air intake, or it is what it is?
Just wondering as , well diablo 93 tune is great!! and besides a good grawling sound with the cold air intake, I don't really see much difference.
