dod/afm disable not working
Re: dod/afm disable not working
I know it is probably going to irritate some here but I'm new and not sure what this disables. Can someone explain? I'm terrible with acronyms and abbreviations.
2017 Camaro SS, Roto-Fab, Soler 95mm ported TB, Flow Tech axle back.
Displacement on demand.... active fuel management... it's the 4 cylinder mode on v8's...
Still haven't gotten this problem fixed.
it was definitely off in the previous Last tune written file you posted.tyler94 wrote:Still haven't gotten this problem fixed.
Please post the current one.
YoSoyGrammy
I'm having a problem with the dod/afm not disabling. I can hear it and feel it. Also, my dashboard shows v8 mode when my engine is most definitely in v4.
It is set to OFF uin the tune, are you 100% sure?
Do you have the V4 indicator on the dash?
Yes. 100% it says it on the dash and I can hear it.
- MagsTuning
So even with setting AFM to disabled your dash still shows it going into V4 and you hear the change in exhaust note?tyler94 wrote:Yes. 100% it says it on the dash and I can hear it.
post your tune file please.tyler94 wrote:Yes. 100% it says it on the dash and I can hear it.
