I read recently where Diablosport apparently stated it was not necessary to return to stock tune before uploading a custom tune. Can anyone confirm this???
Also, my In-Tune came with several pre-loaded tunes already installed. I have had Bama/AM write a few tunes for me (a 91P and a 91R) and i noticed the new tunes i just recieved (to correct an over-rich part throttle cruise condition) have the same file names as my previous tunes.
If i chose the 'Delete All Custom Tunes' menu, will that only delete tunes i uploaded and leave the other 'canned' tunes in place???
Thanks for your help...
In-Tune Questions Ford Applications:
- MagsTuning
Re: In-Tune Questions Ford Applications:
Yes only the custom tunes you loaded to the device would be deleted.
- 2006 Mustang GT
Thanks for your time. Much appreciated!!!!!MagsTuning wrote:Yes only the custom tunes you loaded to the device would be deleted.
- 2006 Mustang GT
No need to return to stock tune before loading a different tune???
- 2006 Mustang GT
Would this delete my stock backup tune???MagsTuning wrote:Yes only the custom tunes you loaded to the device would be deleted.
cant delete backups or canned tunes...
- 2006 Mustang GT
Do i need to return to stock tune each time i.load a custom tune???mikel wrote:cant delete backups or canned tunes...
No... just select the new tune you want to install, and then install/apply it....
- 2006 Mustang GT
Thanks for that info!!!!!06MonteSS wrote:No... just select the new tune you want to install, and then install/apply it....
