C to F
This section of the forum is for discussions relating to the Trinity MX line of monitor devices.
Orrank
C to F
Post by Orrank »
How do I change the units to read as F? The temp gauge has the range to 240, yet reads in C so its low.
Orrank
Re: C to F
Post by Orrank »
Nobody?
Manual tells you how to change units and to change metric to imperial, but im not finding how to change off of Celsius.
Re: C to F
there should be a global option in settings or 2x click on any gauge and change it in the editor.
Orrank
Re: C to F
Post by Orrank »
Thanks for the response, i must be blind. Im not finding it. I agree there should be one lol.
For example I 2x on the IAT gauge, itll let me change the tic marks and range, but not finding the C to F.
Do you happen to have a menu breakdown sheet?
Re: C to F
go to settings and select 'unit of measure' and try changing it there.
Re: C to F
to do a single gauge, 2x click it to open the editopr then at the bottom/middle o the screen there is a switch to go from Imperial to Metric for that single PID.
Orrank
Re: C to F
Post by Orrank »
Yea , i did the Metric to imperial. It stays as Celsius in both. Thats how I assumed it was supposed to work.
Ill try again and restart it. Will report back. Thank you
Orrank
Re: C to F
Post by Orrank »
Ok so ive tried changing it through the settings, and through the gauge editor. Both changing to metric and back to imperial.. no change.
Im mainly looking at the ECT gauge. Has the tic marks to 240 but digital displays 80deg C
Don’t know what else to try. IATs are displayed in F
Orrank
Re: C to F
Post by Orrank »
Beuller?
Orrank
Re: C to F
Post by Orrank »
Solved..
Changed to different ECT gauge in menu.. Thanks!
Return to “Trinity MX monitor”
