Trans tune
bdubblenut
Trans tune
Post by bdubblenut »
My t2 won't allow my tuner to do a trans tune. There aren't 4 folders that pop up for the files, only 2. 14 ram 1500, ive seen other 14 models that had it. I've heard the diablosports were a little funky with the 14 model years, not sure. Any ideas?
Re: Trans tune
Is it an 8 speed?
Our 8 speed TCM support is officially 15+.
There are some 14s that shared cals with 15s and thus are supported but its more of a bonus.
bdubblenut
Re: Trans tune
Yes it is an 8 speed
bdubblenut
Re: Trans tune
So it's basically a shot in the dark wether your truck is able to accept trans tuning or not for 14 models and not necessarily the tuners?
Re: Trans tune
Pot the info.xml file from the device please.
bdubblenut
Re: Trans tune
<tool_info platform='T2'>
<registration sn='201212726' status='0' tool_oem='DIABLO' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r03w'/>
<application name='updater' rev='2r01j'/>
<application name='gui' rev='3r04d'/>
<application name='installer' rev='2r01m'/>
<application name='logger' rev='2r01d'/>
</applications>
<databases dbnames='2r01c' dtc='2r01a' vin='2r01i' SAE='3r01f' GaugeScreens='3r00b' GaugeLayouts='3r00b' Graphics='3r00h'>
<database mfr='DCX' tune='2r02n' pid='2r01e'/>
<database mfr='FORD' tune='2t02ui' pid='2t01dt'/>
<database mfr='GM' tune='2t03pt' pid='2t01ct'/>
</databases>
<system rev='2r01b' config='2r01c'>
<kernel release='4.11.12-rt16-diablo12' version='#348 PREEMPT RT Fri Jan 19 12:17:33 EST 2018'/>
<option name='Wifi' enabled='true'/>
</system>
<last-connected vin='1C6RR7TT1ES328252' mfr='DCX' ecus='2'>
<ecu calid='68153791AD'/>
<ecu calid='68234057AB'/>
</last-connected>
<licenses available='1' tuned='1'>
<license vin='1C6RR7TT1ES328252' mfr='DCX' ecus='2'>
<tuned_ecu type='PCM' calid='68153791AD'/>
</license>
</licenses>
<reg reg='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'/>
</tool_info>
Re: Trans tune
we should be able to downgrade your tcm cal to the AA version which is supported.
Return the truck to stock tune gives a call and ask to force a calibration update to get the tcm updated to add support.
bdubblenut
Re: Trans tune
Okay. It may take me a few days to get enough time to do that when you're open. Is the number in your signature the correct one to call?
Re: Trans tune
Yes, thats the number.
bdubblenut
Re: Trans tune
That worked. I now am able to do a trans tune. Thanks so much
Re: Trans tune
sweet.
Amermuscle
Re: Trans tune
Post by Amermuscle »
When u say return to stock to are u refurring to vehical backup?
Re: Trans tune
Yes.
