Knock with 94 octane
Discuss Predator 2 for Chrysler vehicles
jayman
Post by jayman »
I'm running the DS 91 octane tune with Cheveron 94 fuel. I'm getting 3 degrees st knock at rolling WOT. I've attached my data log and looking for advice thanks...
jayman
Re: Knock with 94 octane
Post by jayman »
I've now also done some 0-100 WOT runs with 2 deg of LT and 6 deg of ST on the 91 tune with Cheveron 94 octane. Any advice??
whats it look like logging the stock tune?
May be in need of a catch can...
jayman
Post by jayman »
Unfortunately I can't view anything I log right now because I only have access to a Mac, my Pc is at work and I wont be working for awhile. I do have a catch can installed. Were you able to open the older log file I posted (cruise WOT)? I was having issues posting before but changed it to a zip file as per your recommendation.
jayman
Post by jayman »
Ran a few WOT runs on the stock tune and I'm getting 5 degrees of ST knk. This is with Cheveron 94 Octane and a catch can. I've attached the datalog. Any advice??
what vehicle is this?
May have excessive oil build up in the intake manifold, time to clean it out or wait for it to burn off and hope the catch can keeps more from building up.
try adding a little fuel in the rma range thats knocking to see if that helps.
Return to “Predator 2 for Chrysler/Dodge/Jeep/Ram”
