Hey Mikel,
So I'm installing a water/meth kit on the truck (roughly 300+ ml of juice), will the pre-tunes (cali) work or should I return the truck to stock and shelf the tuner Trinity 2. By "work" I mean the pre-tunes shouldn't have an issue? I understand I will have to go to a dyno shop to get the max out of the kit, but until then I just want to be safe...
thanks and be safe man
METH!! No not that :)
Re: METH!! No not that :)
well the canned tunes will be better than the stock tune by far, as tuning for meth should include leaning out the fuel mixture and adding timing, both of which the tune does, but it will still need to be dialed in for proper performance.
What vehicle is this?
smkn_cobra
Hey thanks for replying to my post. The kit is going on 16 2.7l EB F150. So glade to hear the turner can handle fuel and timing. Stay safe man!
should wake up nicely if you add some timing to go with the meth, just dont run that added timing if you run out of Meth!!
smkn_cobra
Hey Mikel,
So 2 weeks in and I am still wiring my meth kit lol...So I'd like to hook up a boost cut relay, can the trinity be used as an ebc (electronic boost controller)? Would I need to get a EAS Universal Analog adapter? I'd like to vent boost in the even of a failsafe... Thanks man be safe!
Tricky, not sure how that would work.
You can use EAS to turn things on or off, but i dont think you'll be able to control a boost controller.
