These are the codes I blow since I installed the T2
Mike Ohio
Post by Mike Ohio »
I've installed a cold air system, bigger throttle body, high flow cats and true dual exhaust system, hot street coils and last the T2, I only blow these codes when I casually keep my accelerator steady, if I keep changing the accelerator pedal position, it won't error "much":
P219A
P0133
P0430
P0153
P0420
P2098
I have to clear codes if I drive normally, which is practically every time I drive my 2018 Ram 1500 Rebel 5.7L Hemi. Is there a way I can block these codes? Thank you for input and expertise.
Re: These are the codes I blow since I installed the T2
you need a custom tune...
Mike Ohio
Post by Mike Ohio »
Thanks Mike, it's next on my list.....
Mike Ohio
Post by Mike Ohio »
Had the custom tune done on a dyno and man it was the best decision ever, no more codes and gained 30 ft lbs and the love the consistent power pick up, truck runs really nice, can't compare it with my CTS V with ported heads, racing cam and other stuff though but, love the power band.
awesome.
