JLT Intake tune for GT350
This section of the forum is for discussion relating to the T2 tuner/monitor on Ford vehicles.
lightning
Post by lightning »
Looking for guidance for GT350 JLT intake tune. Fuel trims are 29% and adding 30% to trinity stock tune modifier only changes it by 9%. Looking for MAF transfer or someone that knows the magic amount to add. Thanks
Re: JLT Intake tune for GT350
Wow, you've got big air leak issues man.. You need to check the air intake, headers/exhaust manifolds, and exhaust system itself.. not good... shouldn't be that lean at all...
check the air intake, make sure it's all fully connected/together, and that all clamps/bolts from air filter to throttle body are all TIGHT so no air leaks anywhere...
check the headers/exhaust manifolds and re-tighten all bolts, make sure all TIGHT so no air leaks.. make sure no cracked manifolds, gaskets all good...
check headers/exhaust manifolds connections to exhaust and the whole exhaust system itself, make sure all bolts/clamps are TIGHT so no air leaks anywhere...
Make sure all breather hoses and vacuum lines are all connected where they should be... make sure no cracked/split hoses...
Check around the intake manifold, make sure no air leaks around the intake manifold...
then, after everything is fixed and tightened up, you need to check a new steady driving log.....
lightning wrote: Wed Jan 20, 2021 7:40 pm Looking for guidance for GT350 JLT intake tune. Fuel trims are 29% and adding 30% to trinity stock tune modifier only changes it by 9%. Looking for MAF transfer or someone that knows the magic amount to add. Thanks
Are you tuning this with CMR?
lightning
Post by lightning »
Yes, Long tube headers as well.
lightning wrote: Thu Jan 21, 2021 11:06 am Yes, Long tube headers as well.
Id start with JLT to see if they can provide a known curve for the CAI/MAF combo.
Return to “T2 for Ford”
