T2 Innovate DLG-1
weaselsmopar
T2 Innovate DLG-1
Post by weaselsmopar »
So I have the T2 tuner and I just recently purchase the universal EAS kit so that I could try and log afr. Beside the program crashes everytime you blow on it. I can't get the eas to even show up in the dataviewer program does this even work. If not I have already decided to go-to hptuner if I can't get this working. Any help would be greatly appreciated
Re: T2 Innovate DLG-1
record the log on the device then you can play it back on DV and see the EAS inputs.
weaselsmopar
Thanks for the reply. I will try this. I just wish there was a bit more information on the wiring of AFR gauges and just general usage of the DV app.
weaselsmopar
mikel wrote: Tue Mar 09, 2021 5:52 pm record the log on the device then you can play it back on DV and see the EAS inputs.
So I did a log file as a.matter of fact I ran 2 and then saved the file. Opened file up and no afr log at all in the file.
please post the log here. Please confirm if it was recorded direct to the device or streamed to DV.
weaselsmopar
Here is the log file that is designed by HHP to get all the logging info they are looking for but I still don't get an AFR or the eas showing up.
weaselsmopar
Well it's been almost a month since I posted my log and no reply I am going to assume this forum is dead.
sorry about that. Was the log recorded direct to the device or streamed to DV?
weaselsmopar
This log was recorded directly to DV using the dashboard provided by HHP racing.
weaselsmopar
Well I guess thanks for nothing. Everyone don't waste your hard earned money on this garbage and just go with HP Tuners. I taking out this eas trash and sending it back Diablotuners is junk.
the engineering team is still looking into this.
weaselsmopar
I just thought I would check to see if there was any movement on this issue. After speaking with hhp racing I just went and bought a GoPro to record my afr as they told me this product doesn't work. Also why is it that I have to reboot my T2 Everytime I want to connect to it.
