Puck Problems Now!
- BigBlackDodge
RE: Re: RE: Re: RE: Puck Problems Now!
OK. I've checked and cleared the codes. Reconnected the Puck and the Truck is still very sluggish! I'm beginning to think that I do need a Boost Fooler, because, not only will it not rev past 2200RPM, but it will not build boost past 15psi while the Puck is connected! Without the Puck, it builds 30-35psi. It didn't throw any codes until about 20mins. later though. P0069 again. What do you think guys?
Not one of us knows what the future holds! So the real question is...do you know the one that holds the future?
Re: RE: Re: RE: Re: RE: Puck Problems Now!
i don't think that you can run a fooler and the puck together! someone chime in if wrong.BigBlackDodge wrote:OK. I've checked and cleared the codes. Reconnected the Puck and the Truck is still very sluggish! I'm beginning to think that I do need a Boost Fooler, because, not only will it not rev past 2200RPM, but it will not build boost past 15psi while the Puck is connected! Without the Puck, it builds 30-35psi. It didn't throw any codes until about 20mins. later though. P0069 again. What do you think guys?
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
RE: Re: RE: Re: RE: Re: RE: Puck Problems Now!
Pretty sure you can, the fooler just caps the voltage signal going to the pcm, so i would have the fooler last inline.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Yes you can, I'm doing it with no troubles hitting 44lbs of boost.
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
I had the same problem BigBlackDodge. On the MAP Sensor Pins check and make sure any of those pins aren't pushed back. It happened on my trucks MAP Sensor and when I tried driving it it was sooo sluggish. I ended up going to Dodge and buying a new one for 11 bux. The same thing is possible on the puck! My truck threw 2 codes, one was the MAP Sensor and the other was a Turbo Overboost code for some reason.. GL
07 2500 5.9 4dr 4x4 Big Horn Edition, G56, DiabloSport Predator/Power Puck Stack, AEM Brute Force, Muffler Delete, Silencer Ring MIA. More to come soon..
- BigBlackDodge
[quote="SublmnL"]I had the same problem BigBlackDodge. On the MAP Sensor Pins check and make sure any of those pins arenHey Thanks SublmnL, those are the two codes mine threw the first time I tried the Puck. I will check the pins on all terminals and check again.
