P2008, ]2016 codes after installing new pcm and tune?
2015jeep5.7
So i installed the unlocked pcm and t2 today, and now I'm getting dtc of P2008 and P2016 along with the abs lights for some reason. I'm not sure why? I cleared the codes, but they came back immediately. I hope to hear get some answers?
Re: P2008, ]2016 codes after installing new pcm and tune?
what vehicle is this specifically?
was the battery disconnected when you did the pcm swap?
2015jeep5.7
It's a 2015 jeep grand cherokee 5.7 and yes the battery was disconnected during installation and as soon as I installed.the pcm and did start up procedure as stated in Instructions I had abs lights and cel light throwing a p2008 and a p2016 codes I cleared them with the tuner and they immediately came back?
so you got both codes before even tuning?
Just from the pcm installation?
2015jeep5.7
Yes sir they were on before I tried the tune cam on after the first start up with unlocked pcm
did you do anything else when you installed the pcm?
Is it possible you damaged or bumped the intake runner control connections?
Both codes point to that, so I would probably start there.
2015jeep5.7
As far as I know I didn't touch anything there honestly I donr even know where the runner controller is or where it's located?
2015jeep5.7
Update so I installed my factory pcm and let it warm up and I have no abs lights or check engine lights at all so.its gotta be something with the pcm right??
It would seem that way. Unless there was a loose connection somewhere.
Can try swapping it back again to confirm or give our guys a call to troubleshoot it, 561-908-0040
