Explorer st
larrygaither
Explorer st
Post by larrygaither »
Is there any support for 2023 explorer st?
Re: Explorer st
larrygaither
Re: Explorer st
Thanks, where can I find info regarding the added performance of the tunes?
Re: Explorer st
https://www.youtube.com/watch?v=1hA3ZuB1T1w
https://www.holley.com/blog/post/explor ... _arrived_/
FEATURES AND OPTIONS:
93 Octane Tune – 45 HP / 69 TQ
91 Octane Tune – 27 HP / 58 TQ
87 Octane Tune – 22 HP / 35 TQ
Auto Start/Stop Disable
Disable Speed Limiter
Adjust Tire Size or Gear Ratio
Idle Speed Adjustment
Rev Limit in Drive/Neutral
Global Spark Adder
WOT Timing Adjust
Fueling Adjustments at WOT
larrygaither
Re: Explorer st
Thank you sir.
larrygaither
Re: Explorer st
I currently have an I3 tuner that I had used on my ram but is not married to it right now. Can I use it on the explorer?
Re: Explorer st
hard to say, would need the serial to confirm, but it cant hurt to try it.
larrygaither
Re: Explorer st
S/N 201624794
Tried it several times, says vehicle not supported needs update but nothing changes when I connect to updater.
Re: Explorer st
is this vehicle outside the US?
Re: Explorer st
fixed the update issue, please update once more then try again in the explorer.
Thanks!
larrygaither
Re: Explorer st
You the Man, works like a charm now, thanks.
Re: Explorer st
enjoy!
Return to “Ignition updater”
