Canned tune emailed?
maximusstryker117
Hello, I am curious if the canned tunes preloaded on the devices are able to be emailed. I currently have a 97 mustang GT with an 03 GT motor and if for the time being I would be able to get one of the canned 87/91 tunes preloaded on the device to download onto my tuner until I can find a cmr tuner close once I add boost. “Trinity t2 ex platinum”
Last edited by maximusstryker117 on Wed Jun 07, 2023 4:09 pm, edited 1 time in total.
Re: Canned tune emailed?
what pcm is in the vehicle?
maximusstryker117
It is the 97 pcm as I am running the same harness from before the swap. So npi harness/pcm.
OK, a tune from an 03 will not go in that pcm. What you need is a custom tune specific to the 03 motor for your 97 pcm.
maximusstryker117
Okay, Thankyou. Where is the tool that use to be up I could locate a CMR tuner near me. I don’t know that I have many around for a dyno besides diablosport dealers.mikel wrote: Wed Jun 07, 2023 4:24 pm OK, a tune from an 03 will not go in that pcm. What you need is a custom tune specific to the 03 motor for your 97 pcm.
Lima Ohio 45806
try southern speed inc, he should be able to dial it in via email no problem
maximusstryker117
Thankyou so very much!!mikel wrote: Wed Jun 07, 2023 5:03 pm try southern speed inc, he should be able to dial it in via email no problem
