Dealer updated truck
Discuss Predator 2 for Ford
Wht20truck
Post by Wht20truck »
Took my 2020 2.7 f150 to the dealer for a shifting concern. The dealer flashed the pcm on the truck. The dealer got a p0630 and U0422 in the pcm for an vin not programmed or incorrect after the update. Had to use IDS (ford scan tool) to reset to factory configuration in the BCM and PCM (due to tire size calibration). After getting the truck back from the dealer I attempted to program the truck using the same programmer and it is now stating that the I need to return my truck to factory...not recognizing my truck is the same truck as previously programmed. Or the programmer did not complete to return to stock on the tire size.. thus creating the issue. Truck is back to stock now and I have a paper weight for a programmer.
Re: Dealer updated truck
so you did attempt to return to stock prior to going to the dealer?
Post the device serial number and I will set up a reset.
Wht20truck
X00011200. 201469509
update it and it will reset.
Return to “Predator 2 for Ford”
