DIABLOSPORT KIT - TRINITY 2
Thermodyne
Post by Thermodyne »
Looking for some more detailed information on the Trinity2
Vehicle is a 2023 Charger R/T 345 w/Auto Trans
I'm looking at the downloadable User Manual, but it seems a little light on details, and perhaps out of date. Some of the software mentioned seems to have been superseded. And I watched a few video's, but there isn't a lot of depth in the ones google is pointing me at. They gloss over it worse than the quick start guide.
For now the questions are:
1) Does the unit require a security module bypass to be installed, or does the pcm modification eliminate the need for that?
2) On the gauges, is there a shift light, and if so, what is adjustable with it.
3) What settings are available with the toggle buttons?
4) Once the pcm has been flashed, doe the unit have to remain attached, or can it be removed?
5) Can the unit drive additional devices oem or non-oem? Things like active intake or a fuel pump interrupt.
Thanks in advance.
Re: DIABLOSPORT KIT - TRINITY 2
Yes, any 18+ models require the bypass module. If you ordered a kit specific to your model, it will come with the bypass.
Yes, you can 2x click the rpm gauge and add a shift light through the edit menu that pops up.
The toggle buttons on the device are designed for use with our EAS system to control things like lighting, winches, etc.
Can be removed.
You could get fancy with the EAS system to control lots of things if you wish. Its not something I have seen done though.
Thermodyne
mikel wrote: Fri Apr 05, 2024 11:06 am 1) Does the unit require a security module bypass to be installed, or does the pcm modification eliminate the need for that?
Can be removed.
Thank you. Much appreciated.
By any chance are there more detailed instructions available online?
Thermodyne
Ya, I have that. Problem is that it's written assuming you have the unit in hand. And it refers you to the information that stored in the unit.
is there any other info i can give you?
Thermodyne
No, not at this time. I guess I'm going to try and get my hands on a unit and poke it a bit.
Thermodyne
OK so i have one to poke at and as expected, have a couple more questions.
1) there is a "Jammer CAI" tune. Is this for a specific air box set up, or any cold air intake box?
2) I was expecting to see a 93 octane tune as wall as an 87 octane tune. All I see is Diablo tune, 91 Octane Tune, and Jammer CAI tune as well and the modify tune selection.
I have already updated the unit, so its not a software version thing.
Thermodyne wrote: Fri Apr 19, 2024 12:35 pm OK so i have one to poke at and as expected, have a couple more questions.
its a discontinued CAI we used to offer, but theres no MAF, it just adds a bit of fuel for the added airflow and thus would work well with most any intake that increases airflow
Diablo tune is your 93 octane tune ;)
Thermodyne
OK one last question. When replacing one custom tune with another, (91 tune to 93 tune) is the procedure the same as when replacing the original tune?
yes, just go from one tune to the next, no need to return to stock.
Thermodyne
Great. And thank you.
duuplo2003
Post by duuplo2003 »
mikel wrote: Mon Apr 22, 2024 1:27 pm
2016 Ram 1500 5.7 4WD
Can you run Diablo tune with 91 octane? What octane(s) can you run with Jammed CAI tune?
2016 Ram 1500 Bighorn 5.7L 4WD CCSB
- Intake: S&B cold air intake, 6.4 manifold.
- Exhaust: AFe shorty headers, Flowmaster 50 HD muffler.
- Ignition: MSD Blaster coils, NGK Iridium plugs.
- Cooling: 180* t-stat, V6 efan, clutch fan delete, AGS delete.
Diablo tune is for use with 93 octane. use the 91 tune if thats all you have.
Same for Jammer CAI, its for 93, the version with 91 in the name is for use with 91.
