newbie, srt8 lost 5hp to the tire
Hi all
I recently purchased a predator for my srt8 charger. I had to go through a lot just to get it to take the tune. Finally it took the update and the tune. I had a stage 1 chip in it that i took out to install the tune to have more options w/the programer. The car also has a cai and cat back. After I got the predator tune in it felt slower. I took the car to a local dyno who is a diablo dealer. I had him run it stock and then w/ the predator and the car lost 5hp to the tire w/the programer. Im trying to figure out what to do next. Has anyone else ran into this?
RE: newbie, srt8 lost 5hp to the tire
Its knocking. Log the ST KR. I'd bet its pretty high. You're gonna have to tweak the fuel and spark to eliminate the knock. Then you'll see the power gains. My 07 SRT gained 20hp and 20ft/lbs to the wheels, even with the knock. Without it its probably even higher.
Log KR!!!!
Find some good gas, and go log KR.
What did the A/F look like on the dyno?
Do you have a copy of the dyno sheet?
i paid the guy extra to try and fix it on the dyno and the best he could get it was back to stock. he didnt say anything about loging kr. you could see it was fat on the big end so he was trying to take fuel away. i can try to send you the dyno sheet if that is possible. i spent a lot of money on the dyno for nothing. now i feel that im gona have to spend more and i shouldnt have to.
He was pulling fuel??? Thats never a good idea. He should have been adding fuel not taking it out. These motors are known to get KR when tuned, and adding fuel is the way to address it. I'm thinking you need to go to a place that actually knows the new Hemis and not just any old dyno shop. Logging KR is basic tuning. Anybody who has any clue will do it. You need to find out if this place did it or not, and if they didn't, they need to give you a refund of whatever they charged for "tuning", or you need to log a complaint with the BBB.
thats what i was thinking. i figured if he was a diablo dealer than it should be good to go guess i was wrong. you could see on the a/f it was rich up top guess it needs to be. although the power seemed to drop the more fuel increased. the guy was sweating it he couldnt believe it lost power to begin w/and then he couldnt even fix it. its partly my fault to he is more a mustang guy but if he didnt have the capability to tune the dodge he shoudnt of tryied. its still strange though the predator still shouldve made more power thats what is says it does. i mean how many people are running around w/a tune and less hp then stock. cause the only way you can really tell is if you dyno it.
no response to why it didnt make power in the first place? thats my mane question here. is this an issue? has this happend before or am i the lucky one? its really not the dyno guys fault the car shouldve made more power w/the diablo tune. its the hardest thing for me to understand. to me the car shouldve made even more power then usaual cause of the cai and the cat back. i wanted to put my stage one chip back in and make another pull but i was running out of money. i bet it made more power and not less. guess its a gamble w/putting mods on a car thought i was going in the right direction.
It's difficult to say anything about it without any information at all.
Do you have the dyno sheets from the before and after? When it was stock and after where you say you lost 5hp? Were they done at the same time? The stock dyno wasn't from some time before the Predator was it?
Do you have any Predator logs showing timing, knock retard, rpm, IAT, ECT, etc. along with tracking a/f at the same time?
You said you could see the a/f was fat on the big end. What was it? What was it at other rpms?
What was the timing?
If the dynos were not at the same time what was the corrected sae 5? Using the same gas?
If the dynos were at the same time was the first one cold and the second hot?
stuff like that is helpful/necessary to tell what's going on.
Is this guy a Diablo CMR Tuner? Or is he only a Diablo dealer?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
the guy is a tuner. he kept the graph dyno print outs because he was so discusted and couldnt believe it. it was at the same time. the car w/out the predator and then with. it made 345 to the tire on the first 2 pulls w/out and then he installed the predator it made 340. the same gas the same day. i dont understand why it needs to be tuned at all. the tool says it makes more power out of the box. he is supposed to be doing this but its not making him money so i know his not gonna. the a/f was mid to high 10s while he was running the car. im gonna try and see if he'll email the print outs and then mabe i can email them to somebody that has a better idea about this. in the mean time im gonna make some recordings of the above pids and see whats up. i still dont think this is right to me it shouldve made more than stock (cai/cat back) and then customize and make even more. i feel like im customizing the tune to make what its already supposed to.
I think somethings wrong with his dyno. I've never seen an SRT8 dyno 340, even on the lower reading Mustang dynos. Most make in the 360-380 area on a DynoJet.
The customized tuning is needed because each car is different. The clearances are different, the wear is different, so a canned tune will only do so much as is. That said, a 93 CAI canned tune netted 20rwhp and 20rwft/lbs on my 300 SRT8, so something must be right with it.
Yes, mid to high 10's is very fat. I've never heard of that with the "canned" tunes that come with the Predator. Did he adjust anything on the Predator before he installed the tune?
The tunes provided with the Predator are sort of generic but with only a CAI and exhaust they should be very close. Most people see a/f in the mid 12's at WOT. Odd. Just doesn't sound right.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Also, when you say he's a "tuner" do you mean he is a tuner or is he also a CMR tuner? Does he have the DiabloSport CMR tuning software to create completely custom tunes that are loaded to the car using the Predator. The Predator comes packaged with some tunes by DiabloSport already already on it. Then you can go to a CMR tuner to get a tune file that is completely customized for your application (mostly for more heavily modified cars/engines). If he used one of the tunes that was packaged with the Predator do you know which one it was and what octane pump gas are you using?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
hes a cmr tuner but to me thats besides the point this shouldve made more w/the diablo tune. it was on a mustang dyno thats why i went there. to me the car doesnt and shouldnt need a custome tune like that. the diablo should be able to do it. the car is not heavily modified. im running 93 and i think thats the tune he used he did it in the car so i dont know for sure. the car dynoed 345 w/out the tune. i think theres something wrong w/my predator not his dyno but one never knows. i see other cars up there a lot and they put reasonable numbers
Ok. It is VERY strange that you would see a/f in the 10's with the stock predator tune (you would probably use the included CAI 93 Octane Performance Tune for your car). You're right. You shouldn't need a CMR tune. The CAI93Oct tune should be just fine. EVERYONE I've heard of who uses that tune (I use the CAI91Oct tune bacause that's the best pump gas we can get) saw mid 12's a/f. Many added just a little fuel and some pulled a degree or two of timing to get the rid of the minor knock retard they were seeing because their gas wasn't quite what it should have been.
But a/f in the 10's is way out there. I would think something else is going on.
If the Predator loads tunes to the car there probably isn't anything wrong with the handheld itself. If the tune file loaded correctly to the car and the car ran then it's probably not a corrupted tune file or anything like that. It would be VERY unlikely that there was something wrong with the packaged tune file exactly in the fuel area and the rest of it was fine so that it loaded ok and the car ran.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
- UARPerformance
Never seen that happen with can tune either. Even using just tuner to adjust air fuel & spark makes 20 & 20 usually.
UAR Performance.com
