Was trying to install OEM tune to my 2005 Dodge Magnum AWD R/T 5.7 Hemi, but i always get Restore failed. Parameters axle ratio.
Error etc... and reboot. No previous tunes with other programs. Worked fine over 4 years. Done uggrades etc.
Wanted to test i3 on wife 300C, but cant...
Could the error come, because i have AWD and AWD has 3.07 rear diff ratio and Diablo has only 3.06 etc.
Re: Restore failed. Parameters axle ratio.
go to the quick adjust menu and select restore all quick adjusts, then if that works, do the restore tune and it should go through as expected.
Rrottweiler
Did try that Quick adjust, restore all.... But, it stops to Error, axle ratio.
And did try normal restore, still Axle ratio error.
can you give us a call at 561-908-0040 with the device in the car?
Rrottweiler
Me as Finn calling to US and trying explain problem with my Rally Finglish... Too much anxiety, i think i go easier way and buy another license for i3
