Was gone to the UK for a bit, finally got around to logging a new run with the parameters that you guys asked for. 7.5* max ST KR. 2nd gear, 2K RPM to shift.
Log attached. What do you guys think, where to start?
Second Logged run w/ requested data points
RE: Second Logged run w/ requested data points
I couldn't figure out how to shut the loggin off so it ran until out of memory.... hints??
Try the <back> or <esc> key. The one in the upper left corner relative to the 4 arrow keys.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Re: RE: Second Logged run w/ requested data points
Tried them, no workie.Quick wrote:Try the <back> or <esc> key. The one in the upper left corner relative to the 4 arrow keys.
RE: Re: RE: Second Logged run w/ requested data points
Hmmm, When mine (U-7135 with 9r04) is logging and I press the <Back> button it goes back to the menu with "watch and record" and "Playback" on it. Hopefully someone else can help.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Re: RE: Re: RE: Second Logged run w/ requested data points
That's exactly what I thought I did last time but didn't work this time... maybe a fluke??Quick wrote:Hmmm, When mine (U-7135 with 9r04) is logging and I press the <Back> button it goes back to the menu with "watch and record" and "Playback" on it. Hopefully someone else can help.
No idea. I have not heard of anyone having that problem. Maybe a bad/sticky button on the unit? Does the <back> button work fine for everything else? It would be a pain but you might try reflashing the handheld. Make sure you have any custom tunes saved on your PC. Then restore original backup to the car which will also reset the handheld (unmarry from the car). Then update the CROM on the handheld and start over.That's exactly what I thought I did last time but didn't work this time... maybe a fluke??
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Ran it again and it worked fine with the esc/back... must have been a fluke hang up?Quick wrote:No idea. I have not heard of anyone having that problem. Maybe a bad/sticky button on the unit? Does the <back> button work fine for everything else? It would be a pain but you might try reflashing the handheld. Make sure you have any custom tunes saved on your PC. Then restore original backup to the car which will also reset the handheld (unmarry from the car). Then update the CROM on the handheld and start over.That's exactly what I thought I did last time but didn't work this time... maybe a fluke??
Now, how about that log? You look at it yet?
