08 Tuning Problem
KingCyclone
08 Tuning Problem
I just installed the Predator in my 08 350. Worked great at first but now the engine seems to be starving for fuel in ALL tunes. What is worse when I re-install the original backup I get a check engine light(it does this in ALL tunes as well) and there is absolutely NO throttle response. You can put the pedal to the floor and the truck continues to idle. I have tried installing different tunes and then going back and still no luck. What is going on?
RE: 08 Tuning Problem
Can you read the diagnostics and tell me what the codes are when the check engine light is on?
Insert Clever comment here...
KingCyclone
Codes
Hi. The codes are P242C Unknown, P2291 Injector Control Pressure Too Low-Engine Cranking, and P1000 OBD System Readiness Test Not Completed
RE: Codes
Have you tried clearing the codes to see if it cures the problem?
KingCyclone
KingCyclone
