7130 updated...
Blue2003
7130 updated...
Post by Blue2003 »
ok folks 7130...'05 cummins...updated to 9r02 and DL the tunes....computer said successful...took to the truck of a friends.......did everything as normal...and the predator says thatthe truck is 25325333ag and that the predator is a 25325353AG....written just like that...is there something that i did wrong or is that something MR JOHAN has to fix? what is wierd is that is was DL to truck and running fine before need to update.truck has only had a predator on it its whole life. o...almost forgot...it HAD the 8r29 on it...now it has the 9r02....thank you
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
RE: 7130 updated...
Sounds like it is saying that it has updated your calid.
Blue2003
Re: RE: 7130 updated...
Post by Blue2003 »
mikel wrote:Sounds like it is saying that it has updated your calid.
Mr. Mike..the topic up above is mine also.....is the fix for johan to do? or does my buddy need to send it in to him?
RE: Re: RE: 7130 updated...
I am not following what you need a fix for?
PatriotBlu
Post by PatriotBlu »
If I understand correctly I think this is the custom tune issue. If it's 9rXX you have to flash a standard tune first and then flash one of the custom / downloaded tunes over that. Otherwise, you'll get the CAL ID / uppercase / lowercase thing. Basically it's not broken. You just have to flash a tow / performance / extreme tune that came with the tool first and then flash the custom tune of your choice over that. Try that -- I think it will work just fine.
See the post by Johan in this thread:
http://www.diablosport.com/index.php?na ... highlight=
I hope this helps!!!
Blue2003
Re: RE: Re: RE: 7130 updated...
Post by Blue2003 »
PatriotBlu wrote:If I understand correctly I think this is the custom tune issue. If it's 9rXX you have to flash a standard tune first and then flash one of the custom / downloaded tunes over that. Otherwise, you'll get the CAL ID / uppercase / lowercase thing. Basically it's not broken. You just have to flash a tow / performance / extreme tune that came with the tool first and then flash the custom tune of your choice over that. Try that -- I think it will work just fine.
soooo..........how or what do yoy mean johan mean by installing a diablo tune first?as in programm a tune to the truck do not set it back to stock then dl a custom tune.....i am lost...
PatriotBlu
RE: Re: RE: Re: RE: 7130 updated...
Simple.
1) download custom tune to preditor over computer.
2) take it outside to truck and flash a regular tune (tow, perform or extreme).
3) flash custom tune right over that.
Done.
No....
1. Load a canned Predator tune to the truck.
2. Go inside and load a custom tune to the Predator.
3. Flash custom tune to truck over the Predator tune.
PatriotBlu
Yea? Didn't seem to matter if the custom tune was already in the Predator or not. I could be mistaken but all that seemed to matter was the fact that a "canned Tune" was loaded to the truck first. Again, I defer to the professionals but I could have sworn I didn't have to go back inside and download the new tune....
Blue2003
Re: RE: Re: RE: Re: RE: 7130 updated...
Post by Blue2003 »
mikel wrote:No....
mike...thank you for the info.......my buddy is going out of town for the weekend tho....but when he returns i will do the steps that you have listed..and i will keep you informed.
Blue2003
Post by Blue2003 »
Blue2003 wrote:
mikel wrote:No....
mike...thank you for the info.......my buddy is going out of town for the weekend tho....but when he returns i will do the steps that you have listed..and i will keep you informed.[MIKEL AND PATRIOT BLUE......THANK YOU SO VERY MUCH FOR TELLING ME HOW TO FIX OUR PROBLEM.SEE MY TRUCK IS A 6-SPEED AND THE TRUCK IN OUR TOPIC IS AN AUTO.....THE SMILE ON THE PERSONS FACE....PRICLESSS....OH YEAH....HE SENT ME A TXT MESSAGE SAYING THAT HE BLACKED OUT THE SIDE MIRRORS....THANK YALL...YOUR S.E KANSAS CUSTOMERS....
CSchomer
RE: Re: RE: Re: RE: Re: RE: 7130 updated...
Post by CSchomer »
Mikel, I'm having the same problem with the differing pred tool/custom tune calids but this procedure isn't working for me. I have a predator with calid 05xxx and rev 9r03. I flashed Perf tune to my truck then hooked the predator to my puter and used the DSDLer to DL post r28 Puff Stack Tunes and it said it was successful. Then when I hook the predator to my truck again, I can't find the Puff Stack Tune (or any custom tune) anywhere. I tried going to Options then Custom Tunes but there is no plain english indication of any custom tune. All I can find is the canned tunes on the main/opening menu. What did I do wrong? Where is the custom tune supposed to show up and how do I find it/install it? If I go to Custom Tunes and choose Erase Custom Tune and hit OK, it seems to have erased a tune but never shows me what it erased so I can't tell for sure if the Puff Stack Tune was ever actually in there. Craig
03, HO, 6sp, 4.10, Predator, A2k turbo, GDP 391, Dual BHAF's, 4" exhaust.
johan
Post by johan »
Think we got this issue resolved, shoot me an e-mail and i will send you guys some test croms.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
CSchomer
Post by CSchomer »
Johan, I sent you a PM with my address cuz I don't know if the email sent. Thanks, Craig
johan
Post by johan »
Here is the new tester crom for custom tunes not working.
u7130_cummins-9t04a.crom
(1.77 MiB) Downloaded 329 times
Diablosport INC
