Gas Indicator Inaccurate
51derrill
Post by 51derrill »
Has anyone experienced this problem on a U 7145, 2007 Shelby GT; after loading the 93 Octane Performance tune, my gas indicator is off. Went to buy gas with 4 or so gallons left. I pumped in 11 gallons, which should have filled the tank! Driving away, I noticed that it was a little over 1/4 tank left? Over the next day it rose to (Very Slowly) went up to 3/4 tank. Never had this before! Even the 3/4 reading seems low. Anyone else have this problem :( ?
Thanks/ Bill
Shaken
RE: Gas Indicator Inaccurate
Post by Shaken »
Next time turn the car off when fueling and you will not have that happen.
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
51derrill
Post by 51derrill »
The key was off, however, still in the ignitian. One thought! The drivers door was open? Any Ideas?
Shaken
Post by Shaken »
Nope I had that happen to me on a hot day and left it running with the a/c on to keep the wife and kid comfortable.
Return to “Predator Ford Gas”
