tourque managment and removing it.
duallydave
Post by duallydave »
do the standard trannies have tourque managment?do the extreme tunes remove it?
RE: tourque managment and removing it.
Not sure myself if there is TM in the manuals, but the tunes do not remove it if it is there.
duallydave
is it a safty issue why your tunes dont remove it?is that why the smarty smokes so much?
ropnjessi
Post by ropnjessi »
I think its a safety issue as far as the transmission goes, it will last longer.......
c/p: from another site
The Torque Management system is used by Dodge to prevent full fueling below certain RPM's, speed, and boost. This helps to protect the drivetrain (ie. tranny) and reduces warranty work for them.
Programmers like the BD and Smarty have the ability to reduce or eliminate the TM system altogether. It's definitely not advised on trucks with stock trannsmissions/clutches though.
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
cameroneod
Post by cameroneod »
So is there anything out there that ONLY turns off torque management?
johan
Post by johan »
Nothing that i know of the ONLY turns it off, it comes with some sort of tune. I played around with that a little the other day and it is just a torque table, truck does not feel good when you allow it for that much torque down low(IMHO)and yes it does puff quite a bit more smoke that way.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
PatriotBlu
Post by PatriotBlu »
I have the 6 speed G56. If I pull even fairly hard from under 1300 rpm's on any tune other than tow, I'll leave a plume of smoke that will have Delray Beach's finest looking for the fire. Once the turbo spools (yes, using boost fooler too) say over 1500 rpm, the exhaust cleans right up, however.
Interesting to note that the LOW RPM TORQUE is much more likely to make the stock clutch slip than pushing it hard above 2000 rpm's -- though I can make the clutch come loose at all rpm's on Economy/Performance or Extreme... Gonna need a Southbend Clutch sometime in my future....
JOHAN -- Do we have a reputable clutch installer in our area (Delray / Boca) that can handle the job, including the hydraulic upgrade, etc... ??? Thanks.
johan
Post by johan »
I dont know of anyone local who specializes in that to be honest with you. I always have one guy by our shop do all the work to my truck(he is actually buying it) but I highly recommend him.
Diablosport INC
cameroneod
Johan, what do you mean by, "truck does not feel good?" How likely is it that turning off the tm could tear up a full billet tranny?
dieselbeef
Post by dieselbeef »
i am iterested in total removal(override) of the torq gard in an 02 diesel ram auto
can this be donE with this programmer??
THANKS...2ND POST
madmanwithmouse
Post by madmanwithmouse »
would be nifty if it was cutback according to to the tune installed.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
NEVERENOUGH
Post by NEVERENOUGH »
I used to own another downloader that would remove tq mgmt and it was rediculous and had nowhere near the power of my predator. If i went past 1/2 throttle i had no more power and at take off on a wet road, well it was crazy. I talked to the guys at this company and they said all it was basically was that it tricked the PPS/APPS into thinking you pushed the pedal further than you did and thats why it died at 1/2 throttle. I also had to have dodge replace 2 throttle sensors because of their crap. My dealer is very mod friendly and they said " you have a @^% dont you........ Some of you guys will know what DL i am referring to. I am not going to mention their name on here as i truely believe they are crap. As for the guys with the manual tranny; from what i have been told it would not be advised to try it and i am not sure it would even work. They said that basically you would not be able to use the lower 2-3 gears as it would rev out to quickly. BUT........ Johan and the guys at diablo have worked some serious magic so far so i guess only time will tell. I am also on DTR with DD and Dzilla and the others, you can gain a lot of great knowlede/info there as well.
madmanwithmouse
cant use lower gears... SOOOOO use higher gears :)
ncyz1v
Post by ncyz1v »
madmanwithmouse wrote:cant use lower gears... SOOOOO use higher gears :)
Before I put on the 19.5's I started in 3rd every time.
Now I need 2nd but hey with the Predator speedometer fix.
I am 1400 rpm at 55 1950 rmp at 70mph!
Nick,
Smart Line products
06 Dodge 6 speed,4x4 dually on 265/70/19.5's
predator POWER!!!
95' dodge diesel with 165k that sounds better than my 06?
Herculou
Post by Herculou »
You get better mileage with that set up?
06 CTD, AFE, 6 speed 3.73, predator
