Flex fuel capabilities on current tuners?
jonathanalberto007
Post by jonathanalberto007 »
Diablo Sport guys, I noticed that you guys have launched a tuner with the
capabilities to turn a vehicle with both gas and E85 fuel. Now my question is, since fuel seems to be changing a lot in price, and the E85 is ussually cheaper.
Can the current tuner be updated to have both tunes in them? For example I have a U7193, rev 9.04 and previously being used in a 2004 Chevy Avalanche 5.3L. I ask this because having the option of two different tunes, like the ones mention above and having the flexibility to switch tunes when it becomes necessary. IMO would be something positive to be able to add both in current tuners like mine above.
RE: Flex fuel capabilities on current tuners?
If you want to add a flex tune to your U7193, email; [email protected] for info, he can set you up with a custom tune.
Ill_Born_SS
Post by Ill_Born_SS »
But your fuel system cannot handle the E85, can it?
" Just Friggin Wicked"
Now with TCM support...
Most any vehicles built in the last 10 years at least can handle E85 no prob...
Everything we see at the pumps down here right now is E10, so......
Ill_Born_SS
fuel lines won`t last
also on the 2006 imp ss it states no ethanol for this reason and there are others but yes most cars can handle E10-15% but are eating the lines above that and some even at that
jonathanalberto007
Thank you Mike, for a quick response. I'll get in touch with Andy.
Re: RE: Flex fuel capabilities on current tuners?
Ill_Born_SS wrote:fuel lines won`t last
Can you tell me where you found this misinformation?
Maybe you should see this:
www.rune85.com
RE: Re: RE: Flex fuel capabilities on current tuners?
Ill_Born_SS
Complete with AUTOMAGICAL TCM SUPPORT.
Go figure the 5.3 has the hp&tq increase as the regular ALMOST..
Maybe where you come from all the automobiles come with the stainless lines to support it
Stainless lines, are you kidding me?
ONLY thing that will not work with E/fuel is rubber fuel line hose, and that is no longer used anywhere (except I hear in Lamborghinis, lol.)
Please do us all a favor and check the links I posted, there is lots of good info there that will clear up your misconceptions.
You do realize that many areas of the country can ONLY access E10 year round...do you think they are all in danger of harming their fuel systems?
jonathanalberto007
That is the reason I asked, because I don't get that fuel year round, so by being able to tune my truck to when it is available would be great, at least in my opinion. Save a few bucks over a few months can't be a harmful thing.
Redgto04
Post by Redgto04 »
Lots of good info here also! Very good read! There is so much mis-info out there! Now he says to do it right, you need bigger injectors to keep from maxing the duty cycle out, and killing the life of the injectors.........
http://www.ls1gto.com/forums/showthread.php?t=264727
Re: RE: Re: RE: Flex fuel capabilities on current tuners?
Redgto04 wrote:Lots of good info here also! Very good read! There is so much mis-info out there! Now he says to do it right, you need bigger injectors to keep from maxing the duty cycle out, and killing the life of the injectors.........
Most stock applications will have no problem with stock injectors, but yeah, they may become necessary as you increase power...
Redgto04
RE: Re: RE: Re: RE: Flex fuel capabilities on current tuners
Post by Redgto04 »
I am interested in this also........so what gets changed? Injector pulswidth? Advanced timing? Just curious....
marcoengineering
Post by marcoengineering »
Andy knows his stuff pretty well. There is inherant risk with any type of tune use, I have this FlexFuel tune in my truck and have no qualms with using it. GM uses the same injectors on the 8.1L gas, which is 30% bigger than the 6.0L, so if the same injector can handle the 8.1L then it can handle more flow when needed. BUT if you were to start modifying the engine beyond stock configuration(hardware performance parts), then you would need to look into bigger injectors(even without the flexfuel tune), otherwise the "stock" injectors should work just fine in a stock motor/FlexFuel combination. Everyone has an opinion on this, but those links MikeL provided shows hardware data/parts, not just well maybe if worst case thinking, not to say the opinion of others isn't valid, but if you were really worried about your motor(or durability of your whole vehicle) you wouldn't mess with the stock OEM tune to begin with. This is just another option(like the 87 Tune or 91/93 Tune or the Custom Tune), and personally I like to have it even if I just get the 10%-15% better 100% gas MPG that teh FlexFuel tune gives.
MarcoEngineering
MarcoEngineering
