2003 F-350 6.0L U7165 speedlimit?
amundrg
Post by amundrg »
Is it possible to adjust the speedlimit to 55mph with U7165? (Have V.9.03)
rgds
Amund
lrklyne
RE: 2003 F-350 6.0L U7165 speedlimit?
Post by lrklyne »
I am also wondering about the governer. Is there a way to extend my speed capabilities?
2004 F-350 Super duty Lariat. AFE intake, 4" tubro back, 6" lift, 35x12.5R16 Mickey thompsons.
lrklyne
Post by lrklyne »
It can be removed or lowered to 65 MPH...
lrklyne
Post by lrklyne »
Hi mike. can you tell me how to remove the speed limiter on a 04 f-350?
Select the tune you want to install, then choose modify tune, then modify parameters.
Go to speed limit, and set it to off, then press esc and reinstall the tune.
amundrg
Post by amundrg »
Hi Mike
I have updated to v.9.05, but when I activate the speedlimiter, the engine stops when I put it in gear. And is it possible to adjust the speedlimiter to any speed I want, say 55 mph?
rgds
Amund
WHat do you mean the engine stops, does it shut off?
As far as I know, the lowest you can set it to in the Predator is 65.
amundrg
Post by amundrg »
Hi Mike.
Yeah, the engine shuts off. With the limiter enabled the engine did shut off the second I put it in reverse. When I disabled the limiter the engine kept going. Also, do you know how to adjust the limiter to 65 mph? I can't adjust the speed setting. I have tried several times, but with the same result.
rgds
Amund
To lower it you'll need to update to the 9r05 revision, sorry, didn't see 9r03 at first.
Not sure about the stalling, but it should have nothing to do with the speed limiter.
