U7191 Dyno
FirstGTO
U7191 Dyno
Post by FirstGTO »
I have a 05 Goat, Do you guys have any dyno, hp or tq numbers about your programmer?
FirstGTO
RE: U7191 Dyno
Post by FirstGTO »
Are you guys going to reply? Or is it possible that there is no increase in power using your programmer, and YOU don't want to tell us!
TXGTOU
RE: U7191 Dyno
Post by TXGTOU »
I'm going out on a limb and saying the "your results may vary" would apply. Also, whether you meant it to or not, your last post sounds somewhat antagonistic. That probably won't help you get a definitive answer. I have an 06 GTO and even though as a stand alone unit I don't expect much in the form of gains (maybe 10 RWHP if lucky) but its when you start adding other mods that the Diablosport will help. I recommend getting some bolt-ons, doing some live data logging, and dialing in with the help of the fine folks at Diablosport. Most importantly, remember that you get more flies with honey than with vinegar.....
FirstGTO
Post by FirstGTO »
No offence TXGTOU, but I know about everything you stated. All I wanted from Diablosport was a basic dyno sheet done on their project car. I was an idiot to buy this product last year knowing it will increase my performance but, how much! Now, Superchips has a Flashpaq for our cars, and has a basic dyno sheet to go with it. From now on, I want to know what a product does before I buy it! Thanks for the reply, to bad diablosport doesn't want too!
TXGTOU
Post by TXGTOU »
Try www.ls2gto.com There are many members on that forum that use the Predator. Good Luck.
Re: RE: U7191 Dyno
FirstGTO wrote:Are you guys going to reply? Or is it possible that there is no increase in power using your programmer, and YOU don't want to tell us!
Here is the gains on the automatics, the M6 gains are even larger.
Return to “General Questions”
