Why does my car run better with can tune compared to CMR?
Illss1
Post by Illss1 »
I've had my car redone twice by the CMR tuner and i can't seem to break 12's with either tune with best at 13.0 but before with r16a (no adjustments made to spark/fuel) went 12.83 and with v9.08 it went 12.9 (no adjustments again to spark/fuel ) right off the expressway onto the track . Has anyone else had an issue like this ?
06 Charger SRT8 inferno red with predator (my tune) ,mopar cai ,180 stat........ 12.7 @ 110 and currently 81,000 miles
06 TBSS AWD all stock for now......
08 Jeep Wrangler 4DR redrock w/AEV 6.1 hemiswap and a long list of mods ........
SRT8Tech
RE: Why does my car run better with can tune compared to CMR
Post by SRT8Tech »
Is this an e-mail tune or actually done on a dyno? Anyway, log your CMR tune and the canned tune. See if you are getting more knock with the CMR tune.
2013 SuperBee......................................................
Quick
Post by Quick »
That sounds like a question for the CMR tuner?
Keep in mind that the included DiabloSport tunes ARE "cmr" tunes for the stock or lightly modded car (CAI and exhaust) exactly like yours. And you're talking less than 2/10s. Maybe your tuner likes to keep it more conservative? Maybe your tuner just isn't as good? Ask him.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
SRT8Tech
Post by SRT8Tech »
Was it DynoSteve that tuned it?? I think I remember somewhere in another post that he tuned it.
Illss1
Re: RE: Why does my car run better with can tune compared to
Post by Illss1 »
SRT8Tech wrote:Is this an e-mail tune or actually done on a dyno? Anyway, log your CMR tune and the canned tune. See if you are getting more knock with the CMR tune.
Street tune ...... i emailed a log and it was fine according to tuner on the first tune but i'll log it again an compare .
Illss1
Post by Illss1 »
Quick wrote:That sounds like a question for the CMR tuner?
So can tunes are CMR tunes ? Eitherway i thought the person with the tools to tune are CMR tuners and if its conservative tune then it should be a preloaded tune right? Did i expect to much ? I was looking to accomplish a better time and got worse times with both tunes yet the "CAN-CMR " tunes are doing justice. I cant ask him no more either becuase i feel like a bother and i should'nt have to feel that way . Guess my post is a more of a vent .
tuningss
RE: Re: RE: Why does my car run better with can tune compare
Post by tuningss »
They are ALL CMR tunes. CMR is the name of the software developed by and used by Diablosport and all of thier custom dealers. If you are referring to a tune from a CMR tuner, then that would be a Custom Tune. Just to clarify. :)
http://www.tpctuning.com
Illss1
Re: RE: Re: RE: Why does my car run better with can tune com
Post by Illss1 »
tuningss wrote:They are ALL CMR tunes. CMR is the name of the software developed by and used by Diablosport and all of thier custom dealers. If you are referring to a tune from a CMR tuner, then that would be a Custom Tune. Just to clarify. :)
Thanks ..... but eitherway "CMR" R16 & V9.08 can tunes got me better everything at the track than the "CMR" CUSTOM TUNE an was wondering if thats happened to anyone .
whatever_weirdo
Post by whatever_weirdo »
its called chip master revolution
hope that helps
2006 300c 5.7 dynomax exhaust reso delete afe stage 2 cai 180 t-statand a comp cam now cmr tune with 9r12
whatever_weirdo
what are your settinging for rev limit and mode1 or 2 or stock,and what is the water temp set to thanks im having the same problem can tunes run better the my cmr tune what did you use 93 cai or........
Illss1
Post by Illss1 »
Rev limit in DRIVE is 150 more rpm , fan settings are 186 ls ,196 hs and the i'm on mode "stock" becuase none of the settings worked for my car for some reason and i'm on 93 cai tune . I wish i could get some kind of help from DS to help me understand whats going on or tell me what i should do because the tune i paid for didn't work well at the tracks .
whatever_weirdo
Re: Why does my car run better with can tune compared to CMR
Illss1 wrote:I've had my car redone twice by the CMR tuner and i can't seem to break 12's with either tune with best at 13.0 but before with r16a (no adjustments made to spark/fuel) went 12.83 and with v9.08 it went 12.9 (no adjustments again to spark/fuel ) right off the expressway onto the track . Has anyone else had an issue like this ?
mine was doing the same thing.Then i found out my peak horse power was
at the rear 5700 so i on upshift i used stock and on 6,000 0r 6400 i used stock.now my track time is the same as when it was 9r02 when it was dynoed so now im happier to find out stock is shifting me at 5800 where my dyno sheet tells me my peak horses are try that peace
mike
Illss1
Post by Illss1 »
mike
So ur saying leave the raised shift points stock ? If so i guess i'll try it for the time being til the tuner can have another go at it but he wants me to go to the shop which is far and i dont really have time for traveling. I just hoped for DS to chime in and maybe asking for a log of the tune but that didn't happen same as the tuner too. It's really frustrating to buy something that didn't work as expected then have it redone with same results then going back to a STANDARD tune to be where ur at before .
whatever_weirdo
RE: Re: Why does my car run better with can tune compared to
what was your rwhp and torq and what did he use a dynajet or a mustang dyno
im happy with my tune in stock raised points instead of 6,000 and plus you wont hurt the motor shifting lower and i still get second hard
hope it helps just try it youll notice the seat of your pants dyno lol
Illss1
Re: RE: Re: Why does my car run better with can tune compare
Post by Illss1 »
whatever_weirdo wrote:what was your rwhp and torq and what did he use a dynajet or a mustang dyno
never been dynoed ....... i'll try what u said but u think it'll make any difference with my car being the 6.1?
