Anyone have any experience with high flow cats?
geogasm
Post by geogasm »
I was thinking of buying a pair of Magnaflow high flow cats made for my 07 msrt8
Was wondering if anyone has used them and some feed back from you guys. And if I put these on will I start throwing exhaust codes?
acarroll89
RE: Anyone have any experience with high flow cats?
Post by acarroll89 »
Not sure how they'll work on an SRT8 but ive got them on my ram and im not throwing codes. As long as you have your 02 sensors plugged in, you should be fine.
Black Front Mount Turbo Hemi Ram
IEMS3 Tuned
johan
Post by johan »
the high flows should not throw any codes, they will not really gain you any power either.
Save your money for a cam, aside from the predator and an air intake it is by far the best bang for the buck for either the 5.7L and the 6.1L
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Not necessarily. ON the SRT8s every set of headers throws a code because of the rear O2s. I'm thinking the midpipes may do the same. Sure you could turn them off, but once you need an inspection where they plug into the OBD-2 port, then you're screwed, because the sensors come up as "Not Ready" and you fail.
fordomatic69
Re: RE: Anyone have any experience with high flow cats?
Post by fordomatic69 »
johan wrote:the high flows should not throw any codes, they will not really gain you any power either.
Johan, How does a CAM affect the MDS?
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
whatever_weirdo
Re: Anyone have any experience with high flow cats?
Post by whatever_weirdo »
geogasm wrote:I was thinking of buying a pair of Magnaflow high flow cats made for my 07 msrt8
you already have the highest flowing cats it wont help by buying magnaflows just google your exhaust the stock out performance them there only used for 5.7 or long tube headers
dont waste your money
2006 300c 5.7 dynomax exhaust reso delete afe stage 2 cai 180 t-statand a comp cam now cmr tune with 9r12
geogasm
RE: Re: Anyone have any experience with high flow cats?
Post by geogasm »
Thanks for all your help. I guess last question would be since I don't want to go into the motor just yet, what headers do you recommend and if I change them will I get codes and how do I get around passing emissions when time comes (Mike Levy)
And does anyone else get that rotten egg smell from your cats. when you are stomping on it?? I used to get that smell with my durango and i changed the cat. and it was gone. Thanks again
JonW
Post by JonW »
I have the Magnaflow HF cats on my 07 300C SRT8. They always throw the code - even when the Predator is used to disable them. I can reset the code, but it comes right back within a day.
I do know many others that have them without throwing any codes.
I love the nice bark that they add to my Corsa exhaust, so I just live with the codes. I still have the factory cats that I'll put back on when it is time to get smog tested (and hopefully I have my CARB sticker from Vortech by then too.. :D ).
whatever_weirdo
Re: RE: Re: Anyone have any experience with high flow cats?
JonW wrote:I have the Magnaflow HF cats on my 07 300C SRT8. They always throw the code - even when the Predator is used to disable them. I can reset the code, but it comes right back within a day.
have you dyno it i bet you didnt make anymore horsepower or just sound
cause srt8 have great cats already id love to have your cats for my 5.7 if you want to sell them peace
whatever_weirdo
get a sms 610 supercharger less hassel
nice power like 700 horses try that with a centrfical,see a centrical make power at high rpms where twin screw make power all thru
my 2 cents
