What PID's to watch on SRT4??
What PID's are going to be the most important to watch and record??
RE: What PID
AMB TEMP, ACT, ECT, Open loop FA (AFR), RPM, MPH, AVG PRATIO, PRATIO, TOTAL VE Bank1, EXH PRESS, KNK ST Retard, AV MAP READ, AVG MAP TO USE, MAP TO USE, PTC PEDAL %, ACtual SPK CYL1
That's what I use when tuning.
Insert Clever comment here...
RE: What PID
Thanks Brian! This is Matt by the way, the blue srt you guys used for testing.
RE: What PID
I just took a drive and recorded those pids and it became full. I clicked "Continue" and when I went to click "play back", it said "please log some data so you can playback". does this mean I have to unload it to the computer before I can log again?? I need to get the cable.. Is there a way to erase the info that I loged on the predator?? Thanks
RE: What PID
It should just write over and over.
RE: What PID
It just comes up with a screen with all of the pids I selected. You can scroll up/down but when you click enter, it doesnt do anything..
Re: RE: What PID
do I have to unselect all pids and then select them again??sohfast94 wrote:It should just write over and over.
RE: Re: RE: What PID
No, when you get to the select pid menu hit esc and then it will ask you to log and you select yes.
Ok. Ill try that soon. Ill report back.
Ok heres what I did.
turned key on, pluged in preditor, went to "watch record" and started the car. it had the stars next to the pids I watched earlier. I clicked watch record and I let it record for about 1 min, then clicked esc. I then played it back. All is fine. The car was still running, and I went back to watch record. It told me to turn car on, which it was, so I continued. Then I was back at the same screen i had earlier today, It just listed all the pids I clicked and no numbers or anything.. On top of the screen it says "Live Data". I went back to the main menu and unpluged the preditor, and tried again. I still left the car running. Same thing, screen with all the pids I selected and no numbers. I went to "play back" and it said "please log to view data" I unpluged the preditor and then turned the car off. I went back to watch record and it displayed like new again, all the catagories with the stars next to each one I selected. I guess you cant "watch record" twice until you turn off the car... Very wierd..
Yeah I don't have any answer to that.
Ya, im stumped. Ive tried everything I could think of.. Ill probably just have to come up there one day..
Rage-tek.com
Re: RE: Re: RE: What PID
You dont have to watch all the way through you can puase hitting the center button and press the right and left arrows to move slow. I suppose you could stay in that screen until you note the changes.sfla_srt4 wrote:Ya, im stumped. Ive tried everything I could think of.. Ill probably just have to come up there one day..
PS remember you can use your laptop with the serial to USB cable to monitor you car; with that you can save all the datalogs on the PC
RE: Re: RE: Re: RE: What PID
Ya, I need the cable and a laptop lol.. I have a desktop that I could save them too but that doesnt help me..
My problem is not with watching it, its when I log, I cannot log again until I turn off my car and pull the preditor out and re isert it in the obd2.. Once i record and watch the log, I cannot do anything else with it.. I try to log again, and it wont allow me.
matt i have a laptop if you want to use it someday we both just need the cable.
~James 2004 PT Cruiser GT
