U7146/U7142/U7153/U7158 (old rev) custom tune instructions.
Follow these instructions for transferring files from your Predator to the PC or vice versa.
If you have the U7158 with 8r11 or U7142 with 8r01, use the 05-up Ford custom tune instructions.
U7146_U7142_U7153 custom tune instructions.doc
(28 KiB) Downloaded 4118 times
wanda
RE: U7146/U7142/U7153/U7158 (old rev) custom tune instructio
Post by wanda »
my DSD Downloader says i am not registered, used for 2003 cobra,first time user picked it up new from diablosport dealer in Steuben ME. TDP Automotive. Timmy is the owner he a great guy with dyno and knows a lot about mustangs and outher autos.He has just has not had any time tuning supercharged 2003 cobras, I think he just being very carefull.I had 3 in.pulley with stock air box with K&N filter and silencer removed your 93 octain pulley tune.I understand the 2003 pulley tune is for 2.8 in. pulley and it put us at 12.1 at 2700 RPM and went to 11.0 at4300 Stayed there till 6000 and droped to 10.8 at 6,175.Got off it.With 18 degrees of timing it only made 7 more peak HP. than stock pulley & 93 octaine tune.Made 25 HP more at lower RPM& 50 more ft. lb. tk.Help
wanda
Post by wanda »
Byron username wanda talked to Cristy on Friday I need to get tuner from Timmy.Low on money need to do myself. Have LM1 Inovative Motorsports wideband air fuel meter.Need more timming in pulley tune.Have computer and tuner power up and cable. thanks for help. What do think about 11.8 air fuel and 21 degrees of timing.I have 180 thermostat cooler plugs and Kenny Bell in front fender cold air kit now.did not have them when it was on dyno Thanks Will call as soon as I get my tunner back from Timmy.This has nothing about Timmy,I am low on money. Thanks again.Byron Lubec ME.
wanda
Post by wanda »
2003 cobra my tuner will not let me change baud rates or disengage my traction control.thanks Byron in chilly Maine
frydog
Post by frydog »
i noticed i have a on performance etc. 93 oct. applys to i think it says stock air box?????!!!! i have a factory shacker breather!
should i go ahead and get a custom tune ---
plus im pretty sure i'll need a custom tune if i add a super charger1
06 gt pony
dfw tx.
semper fi.
99SVTCR
99 COBRA PREDATOR
Post by 99SVTCR »
i have a 98-04 ford predator
i hook it up to my car i can read everything but when i go to tune it starts loading and it says this tool is not lisanced to use with this vihicle
toomanyc
Re: 99 COBRA PREDATOR
Post by toomanyc »
99SVTCR wrote:i have a 98-04 ford predator
sounds like your predator is already married to another car maybe ???
JLT true ram air intake
PHP intake spacer
BBK longtube headers
BBK catted H-pipe
Steeda Catback
Steeda Tri-Ax shifter
FMS 180* thermostat
Diablo Predator
99SVTCR
RE: Re: 99 COBRA PREDATOR
Post by 99SVTCR »
how do i change that?
toomanyc
Post by toomanyc »
buy a new one or remove the tune off of the vehicle it was previosly installed on
PHP intake spacer
BBK catted H-pipe
Steeda Catback
FMS 180* thermostat
Diablo Predator
99SVTCR
Post by 99SVTCR »
it wont let me do it i guess im going to call customer support see if they can help me out any.
gordo_2006
Post by gordo_2006 »
Where do i need to set all the parameters to get the best performance out of my 99 v6 with cool air intake and throttle body spacer?
killercobra
Post by killercobra »
i'm tuning a 2000 ford f150 witch is completely stock i want to do the custom tune who know a good set up of peramitors for me to tune?
aregelin
Post by aregelin »
How about a tune for the Ford Racing Cold Air Intake kit? I don't know which one to upload onto the car - Steeda, K & N?
jdoug
Post by jdoug »
Is this .doc file still available? I tried to download it and got errors.
J Doug
2003 Mustang Mach 1
U7146
really?? I just clicked on it and it worked fine for me...
Return to “Predator Ford Gas”
