WHATS WRONG???
carter242000
Post by carter242000 »
off the topic...how do you like the typhoon? any noticeable difference?
grngt50
Post by grngt50 »
have you checked your fuel pressure? Is your fuel pump stock? You said you replaced your fuel filter, right? I would also try running some injector cleaner with your next tank. If you think your pinging......which like described sounds like a glass jar full of marbles........please use your Predator to take out some ignition timing and add more fuel. You will have to test this in small increments until your car is driveable again. Without a wideband it's not going to be perfect but you can make improvements with some alterations in the tune.
-James
LuisMunoz
Post by LuisMunoz »
I personally wouldnt recommend the typhoon, after i installed it there was no difference at all, i think i might have even lost some power, the typhoon os almost like a stock one, the same on the outside for bolt on purposes, but the inside design of the typhoon is almost the some as the stock one VERY little difference, if at all(except for the material its made with). I read somewhere that the typhoon might even make you lose up to 15 horses. Only reason i got it was because the shop i took it to had it laying around bran new and sold it to me for VERY cheap, i needed a quick fix because the stock plastic one was getting pretty bad.
If your looking into buying an intake manifold i would go with a HPS Hardball'r i heard they are some of the best, my friend has one on his gt and he gained like 25 or 30 horses on the dyno
heres a link if your interested
http://www.texashotrods.com/StoreFrontP ... =222304916
2003 Mustang GT auto
Accufab 70mm TB and Plenum
BBK CAI
PP intake manifold
Flowmaster mufflers (no cats)
Diablo sport tune
Motive 3.90 gears
LuisMunoz
Post by LuisMunoz »
No i havent checked the fuel pressure, how do i do that??? and everything that has do do with fuel is stock, even the pump. i did change my fuel filter, and i did it again just yesterday just in case.. should i do that to the WOT settings???
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
BlackFalcoN
Post by BlackFalcoN »
Go see that guy that builds his oun ford race cars and if he has a dyno that would be a bonus.
pre ignition will break the ring landz on the pistonz!!
the typhoon intake manifold is a 1500 to 6500 RPM intake recomended to run with a race cam, high compresstion or super,, turbo charger it was made to port match with the cyl. heads and that stuff, is even on the pro productz web site
sohfast94
Post by sohfast94 »
Wait. you're using 86 octane with a 91 octane tune?
Insert Clever comment here...
grngt50
Post by grngt50 »
LuisMunoz wrote:No i havent checked the fuel pressure, how do i do that??? and everything that has do do with fuel is stock, even the pump. i did change my fuel filter, and i did it again just yesterday just in case.. should i do that to the WOT settings???
Dunno about your car, but on my old 5.0 I can check FP with a gauge mounted to the schraeder valve. You might be able to datalog with FP with the Predator, though. Also, keep in mind pinging is caused by a lean A/F mixture. So less timing and more fuel in the WOT settings, assuming that it only pings at WOT.
Last thing, but still important........if your hearing pinging, LET OFF THE GAS PEDAL!!! Good luck bro
-James
LuisMunoz
Post by LuisMunoz »
no i removed the tune when i pumped 86
Sadly barly even touch the gas pedal anymore :cry:
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
LuisMunoz
Post by LuisMunoz »
i checked the fuel pressure using the predetor and it reads around 20% at idle and at around 30% at part throttle, dont know were these numbers are suppose to be at so can anybody tell me if there are correct or if it needs adjusting... just one question before i change the plugs on the car, what are they suppose to be gapped at???
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
grngt50
Post by grngt50 »
not sure on the gap specs, a Haynes or Chilton manual comes in handy in these situations. As far as the fuel pressure......not sure about percentage values, I've only tuned mechanically via psi values.
Add some fuel pressure at WOT or adjust your MAF curve........back the timing off a couple degrees in the global parameter section and report back
grngt50
Post by grngt50 »
did some research for ya, gap is .052-.056.....don't forget to use some anti-seize on the threads as well. For the record, I don't think changing your plugs is going to stop your pinging. Good luck!
LuisMunoz
Post by LuisMunoz »
ok i changed the plugs and that sound went away at idle but is still there at part throttle and a little bit in WOT, when in idle you can just barley hear i little ticking sound deffenetly not as much as i used to hear it but it is still there
How do i adjust the MAF curve and how mush???
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
grngt50
Post by grngt50 »
do you have headers or an aftermarket mid-pipe? Ticking sounds like an exhaust leak to me
grngt50
Post by grngt50 »
LuisMunoz wrote:ok i changed the plugs and that sound went away at idle but is still there at part throttle and a little bit in WOT, when in idle you can just barley hear i little ticking sound deffenetly not as much as i used to hear it but it is still there
try adding fuel at WOT and back off global timing by 2 degrees first and lets go from there
LuisMunoz
Post by LuisMunoz »
no no headers or aftermarket mid pipe only flowmaster mufflers and i removed the cats from the original H pipe
retarded the timing by two and added 5 to the WOT and nothing it is still still the same
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
Return to “Predator Ford Gas”
