pcm
kevineugene
pcm
Post by kevineugene »
how do i find out if my pcm is bad
kmac1
RE: pcm
Post by kmac1 »
There is no true PCM only test procedure for an end user or mechanic. There is usually a diagnostic procedure for any or all symptoms/codes that may be present in the vehicle. If diagnostics is followed to a T and the symptoms still exist then that is usually when changing the PCM is recommended...
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
kevineugene
RE: pcm
well my car died and when i hook my tuner up to see if there is a trouble code it says can not recognize vehicle
carmos
Re: RE: pcm
Post by carmos »
kevineugene wrote:well my car died and when i hook my tuner up to see if there is a trouble code it says can not recognize vehicle
i had the same problem.call diablo and a tech can walk you through a force install of your original tune.good luck.
kevineugene
RE: Re: RE: pcm
but my car want even crank , it died on me going down the rd, and thats when i plugged my tuner in and it wouldnt recognize my vehicle, that why i think my pcm is bad , i was going to see if my tuner would tell me why my car died .
kevineugene
RE: Re: RE: pcm
is there any thing i need to do when i try another used pcm ?
johan
RE: Re: RE: pcm
Post by johan »
Died on you going down the road, sounds like i wiring issue to me, did you check that out??
A pcm is highly unlikely to just die on you while operating the vehicle.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
kevineugene
RE: Re: RE: pcm
well why want my tuner rocognize my car now that this has happened
johan
RE: Re: RE: pcm
Post by johan »
Not sure why but if it is an electrical short then the whole system might be down depending on where the short is.
Diablosport INC
kmac1
Re: RE: Re: RE: pcm
Post by kmac1 »
kevineugene wrote:well why want my tuner rocognize my car now that this has happened
If there is any type of electrical issue that doesn't allow the PCM to have sufficient power or ground the Predator will not be able to communicate to it properly or even recognize it at all.
"Throwing" a PCM at it is just a guess if you don't do any diagnostics like checking all the basics, fuses, grounds etc...
Kevin@Diablo
kevineugene
RE: Re: RE: Re: RE: pcm
i have chkd all fuses what else could it be
kevineugene
and my security light is flashin real fast
Sounds like the PCM simply failed.
It is rare, but can happen.
Return to “General Support”
