2004 LB7
Jackofalltrades03
2004 LB7
Post by Jackofalltrades03 »
I just tried to modify the tune in my '04 GMC LB7, I got an " Install Faild, Tune not Found " Message. I had sent this unit in and had it upgraded shortly after I bought it in '04 I have a receipt from the upgrade but not from the guy I bought it from at " Running With The Devil " in '04. My unit ID and Customer # should be on file.
My software revision is 1.11 and hardware is 1.00.
What Do I need to do?
rydnhi4x4
RE: 2004 LB7
Post by rydnhi4x4 »
You may need to download the newest revision (9r05) or send it into DS to have it checked out.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
Jackofalltrades03
What kind of amazes me is that other than the Tunes not being there. The Diagnostic and OBDII functions all work including reading real time data.
It's seems like just the tune files got corrupted or deleated. Since I haven't messed with it in a few months ( and it worked fine before ) I'm more perplexed. I can't imagine there is a battery type memory for just the Tune.
Unit is to old to do the internet updating thing. I had to load a patch way back when I first got it in '04 because it gave an engine fault out of the box. After that patch worked I was instructed to send it to DS for an update which they did. Again in "04.
rydnhi4x4
Post by rydnhi4x4 »
Looks like you may have to return it to DS or maybe the Techs can help you online/phone call.
Jackofalltrades03
That's what I was thinking, Tried to call earlier. They must be off till next week. Even tried the guy I bought from. Looks like he sold out and they new guy's only deal in FoMoCo
rydnhi4x4
Post by rydnhi4x4 »
That sucks. Good luck. DS should be able to help.
Thats odd.
Not sure about that error message.
I'll have to wait till Johan gets in later this week to see if he has a solution.
Jackofalltrades03
mikel wrote:Thats odd.
My thoughts exactly on being odd, Especially since what I was trying to do was to go from the med high tune to the economy tune when it happened. But it let me restore the Factory Tune ???????
I can't imagine losing Just the Tunes ........
I really don't mess with the truck that much, It's just kind of fun to spank Mustangs and Tuner cars with a Dualley.
Most of my play comes from C5 Corvettes. I'll get into them all they way, So I do understand The Who what where and why of electronic tuning. I haven't found my cable yet to hook this up to the PC and see if there is anything there yet. I haven't done that since I had to get a Flash in '04 for a engine light after first installing it. Then you guy's loaded all new tunes in Feb of '04.
It isn't real fun driving this truck stock :(
Jackofalltrades03
Anything Yet?????
Is he coming back this week or next? Just curious
Anything Yet?????
I believe he will be back today.
Jackofalltrades03
Anything Yet?????
No Johan Yet????? Image
Jackofalltrades03
Do I just need to send this in after getting an RMA????
Jackofalltrades03
I really would like to get some kind of answer to this before sending it in. I don't understand how this could just loose part of it's function.
I PM'd Johan, no responce.....
I would go ahead and send it in, let us check it out on the bench.
