U7165 surging problem
grumpy929
Post by grumpy929 »
Alright let's try this again. My truck is a 2003 Ford Excursion 6.0 powerstroke. My predator is an U7165. v.9r05 Calid: VXAP2A2
The problem I am having is a surging at around 1750-2000 rpm (More annoying than anything) It is also throwing trouble code P2290 (Injector Control Pressure Too Low) when the tunes are installed.
Previously, I thought it might have been an injector problem. I had the dealer fix the injector issue. Installed tune when I returned from the dealer and had the same problems as before I took it to the dealer. So I put the truck back to stock tune (which of course immediatly dropped my fuel milage to about 13 MPG)
With the stock tune installed, I do not have any surging or any trouble codes. This leads me to believe that it is the predator causing the problem.
I would like to run the predator on my truck but, without the surging and code throwing. Any help would be greatly appreciated.
Thank You
2003 Ford Excursion 6.0L
S & B Intake, MBRP 4" Turbo Back exhaust, DiabloSport Predator U7165
Cal ID: VXAP2A2
I Might Be Slow But I'm Ahead of You
RE: U7165 surging problem
Is this with the 60 HP tune, 100 HP?
grumpy929
Post by grumpy929 »
100 Hp tune
Cal ID: VXAP2A2
sohfast94
Post by sohfast94 »
Unfortunately the code thing might be there although if you posty your last tune wirtten I might be able to fix the surging for you.
Insert Clever comment here...
grumpy929
Post by grumpy929 »
File should be attached
custom_tune.frg
(22.25 KiB) Downloaded 244 times
Cal ID: VXAP2A2
grumpy929
Post by grumpy929 »
custom_tune.frg
(22.25 KiB) Downloaded 252 times
Cal ID: VXAP2A2
sohfast94
Post by sohfast94 »
Try this... and make sure you get back to me on any changes so I can track this issue.
custom_tune_grumpy929_01.frg
(153.6 KiB) Downloaded 325 times
grumpy929
Post by grumpy929 »
Seems to have smoothed out the surge. No trouble codes were thrown. I will drive it for a day or two and post how it does. Thanks
Cal ID: VXAP2A2
sohfast94
Post by sohfast94 »
No problem man. anytime.. If it solves the problem I will release a new rev to make sure everyone gets the same...
powerstroke41
Post by powerstroke41 »
I have the surging prob right before i come to a complete stop.
powerstroke41
how much will a trinity retail for and when will it be avail. for a 2006 f250 powerstroke 6.0
$799, should be available in a couple weeks.
grumpy929
Post by grumpy929 »
The new tune seems to have fixed the surging issue. I am still a little concerned about the trouble code (P2290) that appears from time to time. Other than that, it seems to be a good tune.
Cal ID: VXAP2A2
