Does the Predator Ignore the second O2 sensor?
Quick
Post by Quick »
You wouldn't care if it doesn't work if you've removed your cats. If you haven't removed your cats then it can tell you when they aren't working rather than finding out at an inspection or just before when and if you restore the stock tune. There is the slim chance of just getting stopped and checked for illegal mods. They did that once outside of Infineon raceway. They set up a vehicle checkpoint after the evening drag races and were busting people for non-approved mods.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Letxen3
Re: RE: Does the Predator Ignore the second O2 sensor?
Post by Letxen3 »
Mike_Levy wrote:
turbofan wrote:
is there any way to add this to the next revision of the standard 93 oct. tune? it can't hurt anything....
Can't hurt anything? Its an instant failure of an OBD2 inspection. Many of us need to pass that to keep our cars on the road.
but normally if you take your car to dealer for inspection or for emissions inpection one should flash there car back to stock anyways, no? and put the factory exhuast system back to stock.
~James 2004 PT Cruiser GT
apexanimal
RE: Re: RE: Does the Predator Ignore the second O2 sensor?
Post by apexanimal »
just zip tie it out of the way... easy and replaceable ;)
'03 5spd PTGT w/ all the trimmings.
turbofan
Re: RE: Re: RE: Does the Predator Ignore the second O2 senso
Post by turbofan »
apexanimal wrote:just zip tie it out of the way... easy and replaceable ;)
c'mon apex, don't i get enough of you on ptcrew?
(only kidding)
i thought we had come to the conclusion that without Stage 1, the zip-tie trick doesn't work.
i have 2 spark plug anti foulers in place. when i first started the car i had a check engine light. i drove it an hour or so that night. the next morning, the engine light was off and it hasn't come back on. so i guess the trick is working.
apexanimal
(only kidding)
you can't get away from me... i'm everywhere.
the antifouler will work but it'll take some testing and adjusting to get it right... sounds like you got it...
the comp looks for a difference in signal between the upstream and the downstream sensors... so by zip tying the d/s sensor into fresh air, it'll think your cat is working perfectly...
which is basically what you're doing with the anti foulers... just getting the sensor out of the way enough that it doesn't read nearly as accurately as it would otherwise be...
Letxen3
RE: Re: RE: Re: RE: Does the Predator Ignore the second O2 s
Post by Letxen3 »
is it bad to have the downstream sensor connected with out a cat?
sohfast94
Post by sohfast94 »
Nahhh
Insert Clever comment here...
never_satisfied
Post by never_satisfied »
+1 for the non-fouler mod. been running for over 2 years/10k miles (05 n-srt4 stock pcm) and have never thrown a code...
