Problem with Predator
03silversrt4
I have and 03 SRT4 with big turbo and all of the supporting mods. Well I was having problems with 9r13 not changing my rev limit so i updated to 9r16 now it still wont change my rev limit and now when i nail it anywhere below 4k it runs REALLY lean like upper 13's afr but as soon as i get past it then it instantly drops to 9.0... Before the update it would run really rich on the 93 performanc tune now it does that. then the last thing is my paramaters to change wot fuel at 6-7k are gone 6-7k spark is there though. Oh and for some reason it says my speed limit is over 56,000. I tried to download it again but it still doesnt work. I forgot one more thing about running lean. I datalogged with my dtec and when its running lean it says my injector duty cycle is in the teens even dropping to around 6% but then when it goes rich they jump to the 80's.
Any help would be greatly appreaciated.
Calid is 04510055AC
If you need any other information just let me know
Calid is 04510055AC
03silversrt4
03silversrt4
when i originally flashed PCM with the DS and before i tuned it, it would run in the 9's AFR then i tuned it and everything worked fine except i couldnt change the rev limit. So then i figured i needed to up date it in order to change the rev limit but when i did everything went to hell... It still wont change the rev limit and from 0-4k it runs upper 13's afr until right after 4k then it drops to low 9's. So why would the AFR's change like that with just an update? also why am i still not able to change the rev limit?
03silversrt4
You have a big turbo and other mods trying to run a tune that is made for a stock car.. You need to rescale the injectors, Map/tip(if their changed) and get a custom tune for the mods you have.. You need to contact Rage, or some of the other internet vendors to write you a tune.. Visit SRTFORUMS and go to the "Diablosport Workgroup" section and cruise around there.. There is TONS of info there and make sure to read all of the stickies up top.
03silversrt4
Denver8898
never_satisfied
28patrick28
03silversrt4
