help srt-4 has a problem
streetsteve
Post by streetsteve »
i got a diablosport, 3 inch side exit and hks ssqv and a fm wastegate actuator, if i hold like 17-18 psi for more than 5 seconds like in 4th or 5th gear it pulls strong then when i let off and get on it again i only get 12 psi until i hit 4000rpm then it will go up to 15 psi, if i turn my key off and restart the car it's fine until i hold boost for more than a few seconds, forward motion thinks it's my waste gate duty cycle, anything i can try to fix this. oh yea car is a 2005
chrisgst99
RE: help srt-4 has a problem
Post by chrisgst99 »
u check for any boost leaks?
sfla_srt4
Post by sfla_srt4 »
are you running the included 93 perf tune?? Then yes, the WGDC% will be off. They are scaled for the stock WGA and not the stiffer FM WGA..
streetsteve
i'm going to check for boost leaks in the morning, yes i am using 93 octane, could i just have shit gas and it's knocking and pulling boost? 2nd and 3rd gear are right at 17 psi but 4th and 5th almost hit 20psi
sfla_srt4
Post by sfla_srt4 »
is it knocking??
sohfast94
Re: RE: help srt-4 has a problem
Post by sohfast94 »
streetsteve wrote:i'm going to check for boost leaks in the morning, yes i am using 93 octane, could i just have shit gas and it's knocking and pulling boost? 2nd and 3rd gear are right at 17 psi but 4th and 5th almost hit 20psi
there could be a multitude of things going on. I would have to see a datalog. As for the boost levels that doesn't sound bad.
Insert Clever comment here...
streetsteve
RE: Re: RE: help srt-4 has a problem
what parameters do i watch for knock tot knock ret? tell me what parameters to datalog and i'll send them to you
sfla_srt4
Post by sfla_srt4 »
knock ST, knock LT, RPM, MPH... check out this thread..
http://www.srtforums.com/forums/f384/wh ... og-484265/
streetsteve
ok i ran it again tonight and it didn't do it, but i still datalogged, this was the first time in 2 weeks it didn't do it, it was also the only time that was late at night, maybe temp has something to do with it, let me know what you think about the data log, thanks
the log has a couple of wide open throttle runs
sohfast94
Post by sohfast94 »
Yeah you definitely got a problem alright. It's not the programmer though. Post you last tune wirtten.
streetsteve
here is the last tune written, what was the problem?
i'm not sure why the tune says custom, all thats modified is when the fans come on because i got a 180 thermostat
heres a list of my mods
aem short ram
predator of course
maxxfab 3 inch side exit no cat with a resonator
3 inch o2 housing
180 thermostat
race motormount inserts
05029832AE_custom.drg
(2.25 KiB) Downloaded 165 times
streetsteve
is it something i can fix by changing the parameters?
streetsteve
hey brian can you give me some info as to what my problem is thanks
sfla_srt4
Post by sfla_srt4 »
It may need to have the WGDC tables set for the FM WGA.. Give him some time, im sure he will get back to ya!
streetsteve
it's not boosting too high i even turned the boost down to 15 psi with the wastegate and still did it.
