Rescaling tune for bigger injectors
parsonsproject
Post by parsonsproject »
Dodge 2004 srt-4
Have a bad injector, new bigger ones coming very soon, would like to have my tune rescaled beforehand so once I get the injectors everything is ready to go.
Who can help? How quick can you get it done? How much?
Thanks!
RE: Rescaling tune for bigger injectors
Johan did mine. Its just a base toon though. It will have to be updated and corrected on the dyno.
parsonsproject
You mean the WOT afr will need to be adjusted and tuned, correct? That is a given.
Since I have no ability with the trinity to adjust fuel/injector tables for idle/part throttle and such, the rescale is so the ecu gives the correct fuel for the bigger injectors at idle/part throttle, so I'm not dumping fuel and running rich during normal crusing.
Right. He'll adjust for the larger injectors, but it will only be a baseline tune. He (or anybody else) can't dial it in without having the car on a dyno with a wideband though.
parsonsproject
Having a guy over a srtforums.com do my rescale for $50, he's done quite a bit of rescales with good success.
Return to “General Support”
