Brian are you there? In the latest Tune files I am having acceleration problems at highway speeds. At 70 mph if I punch it to the floor it downshifts and begins to accelerate as usual, then it up shifts then downshifts then upshifts again. It does this several times so I have to just let off the accelerator and not pass. Never had this before with the old predator. Had this problem with Superchips but downloaded that tuner and benched it.
Unrelated but what is KAM? Keep Alive Memory. What happens in a reset of this.
Torque Converter lock up
Excursionist
02 Excursion 7.3 liter
Monster Exhaust w/Power Elbow
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Updated U7170 v-9r03
Edge Juice w/Attitude
Cal ID TNAA7Y5
Transmission Transducer, Solenoid and Springs
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Excursionist
RE: Torque Converter lock up
Hey no answer on this post yet. Anyone there?
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Re: Torque Converter lock up
Mine done the exact same thing.(weird shifting that is).I loaded the 9r04 and bumped the line pressure up..problem solved.Hope this helps.Excursionist wrote:Brian are you there? In the latest Tune files I am having acceleration problems at highway speeds. At 70 mph if I punch it to the floor it downshifts and begins to accelerate as usual, then it up shifts then downshifts then upshifts again. It does this several times so I have to just let off the accelerator and not pass. Never had this before with the old predator. Had this problem with Superchips but downloaded that tuner and benched it.
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
- strokethis
I ran iinto the same problem but is was because my torque converter had a malfuncition and wouldn't hold up to the power, the warmer the vehicle got the worse the problem, try driving it cold and see what it does. This was a brand new out of the box converter with tripledisk lockup, billet front cover and so on.
Its not what you buy, it what you build.
predator programmer,adjustable HPOP module, Overboost eliminator, intake, 5 inch exhaust, banks wheel, built trans, manual lockup switch, 315's and 100hp sticks. 400hp and 900ft lbs to the ground.
Lastest tune files?! last time we spoke you were good were you not?
Insert Clever comment here...
Excursionist
Last time we spoke I had just got the tuner back upgraded from diablo untested. My line pressure is not a problem. Driving it cold makes no difference. its not the tranny or converter. Had this problem with a Superchips tuner and got rid of it and went back to the Diablo tuner with no problems. this was just before I sent it in for the upgrade. Was trying Superchips because of the Theft System problems I was having with Diablo and no support.sohfast94 wrote:Excursionist wrote:Brian are you there? In the latest Tune files I am having acceleration problems at highway speeds. At 70 mph if I punch it to the floor it downshifts and begins to accelerate as usual, then it up shifts then downshifts then upshifts again. It does this several times so I have to just let off the accelerator and not pass. Never had this before with the old predator. Had this problem with Superchips but downloaded that tuner and benched it.
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Excursionist
RE: Re: Torque Converter lock up
So here we are again just like before when I turned to Superchips..No Brian(Sohfast).. and no support?
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Cal ID TNAA7Y5
