Cruise Control problem with Predator!
bigmatti
Post by bigmatti »
Just recieved my predator and have done the perfomance setup, very satisfied with the Predator, it made my Hemi go like a dragster...
But one problem came up, my cruise controler stopped working now, except for the normal settings in perfomance tune I have also changed the auto shift to mode 2, disabled MDS system, increased shift point to 6000rpm and have also changed the speed limiter to 190mph, nothing else?
I also have another question, I got Borla Agressive Cut back system on the car, do I have to do any custom tuning to enjoy some extra horsepower from the car?
RE: Cruise Control problem with Predator!
What revision?
bigmatti
Post by bigmatti »
R17, tried to changed the auto shift option to stock again and the same problem, cruise control wont work at all. Tried all three of them mode 1, mode 2 and stock, same.
What year/make car?
Gulliver
Post by Gulliver »
Hello
I have this problem on my 300C (european one) when trying predator.
It now work after disconnect and reconnect vehicule battery for approx 1 hour.
don't know if it could help.
hemipilot
Post by hemipilot »
I have the problem as well. 2005 Hemi Magnum, installed 91 perf tune, cat back exhaust. The cruise works between 70 and 75 mph...no where else! Weird. Otherwise, great product!
Mikel - any ideas here?
Revisions...?
hemipilot
Post by hemipilot »
mikel wrote:Revisions...?
R17
johan
Post by johan »
Try what Gulliver did, disconnect the battery for an hour and see if that cures it.
I would also try to put it back to stock and see if it works then, i would try the battery disconnect first though.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
fireman2118
Post by fireman2118 »
I had same problem. I restored stock tune. No fix. I pulled fuse 11 for 30 secs. Everything fine now.
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
