When I get on the gas pedal, after it idles back down the whole truck shakes extremely bad, it stops after I let off the gas all the way. like its the engine, started after installing the chip. Problem??
689076337878
2006, dodge ram 2500 5.9L 4wd
shaking problem
Dodge2500 diesel shaking problem
RE: Dodge2500 diesel shaking problem
When was the last time you changed your fuel filter?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
michaeld2500
I have not changed the fuel filter. It shook again really bad today, when I went over some really bad potholes at about 65 mph..
That sounds like something mechanical, bad ground or something.
I personally change the fuel filter every other oil change.
Diablosport INC
Diablosport INC
- ranger_dog
The 65 MPH pothole thing sounds like the dreaded "death wobble" dodges are known for. Shaking from getting on the gas isn't the same thing but hitting a bump and having a severe shake is. Things that cause that are, improper alignment, worn steering stabilizer, worn tierod ends, etc. I added a 2" leveling kit and got it bad.
Thanks, Ed 06 2500 QC 4x4 CTD, Auto, 3.73's, 275/70/18's, Thuren/Carli/Bilstein susp mods, 4 inch duals, K&N Filter, Modified intake, Predator & Puck, Quadzilla Cmdr & boost fooler, more to come.
Never even heard of that but good call man..
Diablosport INC
Diablosport INC
- ranger_dog
If you want to see it in action, try this link http://www.thurenfabrication.com/dwctdslow.wmv It's available on Thuren Fabrication's website. I am running several of his products on my dodge to eliminate the problem I had. Works great now and with larger tires too. (larger tires exaggerate the condition) Anyway, good luck michaeld on fixing the problem.
Your truck also has a 2 piece flywheel, Ive seen some that were shaky from this.
2003 Dodge 2500 Cummins, 6-speed, straight pipe, DS Predator and puck, K&N Cai
Re: RE: Dodge2500 diesel shaking problem
Excellent videoranger_dog wrote:If you want to see it in action, try this link http://www.thurenfabrication.com/dwctdslow.wmv It's available on Thuren Fabrication's website. I am running several of his products on my dodge to eliminate the problem I had. Works great now and with larger tires too. (larger tires exaggerate the condition) Anyway, good luck michaeld on fixing the problem.
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
