Is there documention that shows all the real time data??
mark03ram
Post by mark03ram »
Looking for something that breaks down the real time data parameters. What does each section contain and what does each parameter stand for?? The basics are obvious, rpm, coolant temp, fan, ect. What about the other abbreviated parameters.
Maybe a description and multipliers if needed so they make sense. Trying to figure out a lack of power issue with my truck and figured I might be able to log more indepth info to find the issue.
BTW its a 03 3500 with the 305/555 U7130 predator on the non stacked performance tune. No puck installed at this time.
duallydave
RE: Is there documention that shows all the real time data??
Post by duallydave »
ive been looking for this too,when i look at it it looks like its in hiroglifics.hehehe
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
duallydave
your a member of the dtr rite?do a post on there and see what comes up,theres some real smart guys on there.
Herculou
Post by Herculou »
What is the DTR? and how do I get there?
06 CTD, AFE, 6 speed 3.73, predator
mark03ram
Post by mark03ram »
Nothing so far, I cant believe there is no documentation on these parameters, that is crazy. I can not be the first guy that wants a break down and use's real time data.
chy46
Post by chy46 »
ME TOO !!!
trik396
Post by trik396 »
I replied on DTR about this subject. I have used the Diablo's real time date for trans temp, trans pressure, trans output shaft speed, intake air temp, intake temp in manifold, HPCR pressure which is in Mpa (to convert to psi multiply by 145), boost which you have to subtract normal air pressure of about 14.7 depending on your elevation. A bunch of other stuff that I can't remember right now. But there is alot more that I have no idea what it's telling me.... I too wish there was some type of paperwork describing what exactly I'm looking at. There is injector information but I can't figure out what I'm seeing... and that would be a HUGE plus if we can watch each individual injector and see what they are doing.... 8)
mark03ram
Post by mark03ram »
Mine wont display the trans temp, or the preassure, I did play with the cr press, thanks for the multiplier. I just dont understand why everyone only does 90% of the job, I mean there is some great features in the pred, but would be nice if the documentation was better.
madmanwithmouse
Post by madmanwithmouse »
Now that WOULD be a +, then we could know if an injector was shot!
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
johan
Post by johan »
Man, i have just done some serious digging and i can not find anything that describes the pids, ill look some more, if I find anything thats not too incriminating i will pass it along. :D
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
