need help johan
Blue2003
need help johan
Post by Blue2003 »
just downloaded the v.8r28. it is the group in the sticky thats says post r28 i believe. went out to the truck downloaded the rkl exe.drd and when i finish waiting on the process went to start the truck it idled fine, tapped the go pedal and the rpm shot up to 2100 and would not idle back down. what has happend? do the other three programs do that? i wanted this set of programs because i needed no timing and wanted the puffer tune. does any of these programs like the one i have downloaded or the puffer have timing added? does this set of tunes require the puck use? i am running the TST without adjustable timing that is why i needed no timing.
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
duallydave
RE: need help johan
Post by duallydave »
the stacker tunes will be labeled stacker and they have iether less timing or no timing,and some of the rkl tunes will state less timing.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
Re: need help johan
Blue2003 wrote:just downloaded the v.8r28. it is the group in the sticky thats says post r28 i believe. went out to the truck downloaded the rkl exe.drd and when i finish waiting on the process went to start the truck it idled fine, tapped the go pedal and the rpm shot up to 2100 and would not idle back down. what has happend? do the other three programs do that? i wanted this set of programs because i needed no timing and wanted the puffer tune. does any of these programs like the one i have downloaded or the puffer have timing added? does this set of tunes require the puck use? i am running the TST without adjustable timing that is why i needed no timing.
Johan has isolated an issue in these tunes, and will be taking them down until he gets it squared away. In the meantime, please refrain from using these tunes.
