help?
Blue2003
help?
Post by Blue2003 »
johan or somebody i have downloaded all of the custom tune and all of them raised the rpm when i started to drive it. my gut was tell me while i was downloading the new toons to leave it alone. i had the v.8r21 updated to the v.8r28 and it has mad me pretty upset. has this problem been solved. fixin' to make a long trip and need a piece of mind of safety. please help.
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
duallydave
Post by duallydave »
load the factory tunes and do your trip,when you get back the custom ones may be fixed,all the factory ones are still there,load the tow tune if your towing.johan is working on the new tunes in his spare time f away from the hemi tunes. glad to hear you got them loaded though,mine did the same thing but other trucks ran like a top.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
duallydave
also if you want some more options go to the homepage and find the r27 crom and load that and then you can use the pre r28 tunes in the sticky and they have some that have less timing or no timing and they all work well as i have tried them all,when johan gets a chance im sure he will make those tunes avaiilable for the r28 soon.
Blue2003
Post by Blue2003 »
duallydave wrote:also if you want some more options go to the homepage and find the r27 crom and load that and then you can use the pre r28 tunes in the sticky and they have some that have less timing or no timing and they all work well as i have tried them all,when johan gets a chance im sure he will make those tunes avaiilable for the r28 soon.
dave do these new r28 rkl extreme and or the puffer toons blow soot everywhere?? i hope so!!!!!! do they run good with the puck like the stock extreme stacker, or do they romp out pretty good without the puck?
Blue2003
Post by Blue2003 »
so.......the r27 version toons do not idle up the engine? where do you go to after the home page to see the none timing toons i need?
duallydave
the tunes are in the sticky on the predator forum,the r27 crom file is on the home page,you need to install the r27 file then you can use the pre r28 files on the top of the sticky,find your calid and load em up.thier all good.no idle isules,the idle thing hapend when johan tapped into the torque managmnet thing,hes on it and will figure it out soon,
modified03
Post by modified03 »
I'm having the same problem with the idle it idles non stop just sitting there till I take off. I got the first round idle one work but it didn't blow more smoke less if you ask me but the down low tourque was awsome just the rough idle
duallydave
i never had any issues with any of those ones,and i agree mit be less smoke,maybe the tune burns the fuel more down low hence the low end power,and the less smoke.
