Race only tunes?
Race only tunes?
I use my truck for allmost exclusively racing, and some street driving. Im looking for a tune that will work with what I have and will be best for 1/4 mile. Is this possible? I am running a custom tune that Johan sent me last year, and I am going to try out the new puff tunes.
I am running:
Edge Hot Juice
Dr Performance Predator
Diablosport Predator (on custom extreme stacker)
IIS Silverbullet
Banks IC and High Ram
DDP 50 HP Sticks (soon to be upgraded)
AFE stage 2
MBRP 4"
IIS stage 2 CP3
IIS Dual feed line
BD Top Speed Eliminator (with tq man delete)
NX Express .125 shot (single stage)
Studs
Full Race NADP Tranny
My goal is mid to low 11's using this product, can it be done?
Any good idea's?
Kevin
I am running:
Edge Hot Juice
IIS Silverbullet
AFE stage 2
MBRP 4"
IIS stage 2 CP3
IIS Dual feed line
Studs
Any good idea's?
Kevin
- duallydave
- duallydave
RE: race
i wonder if you used a tune with timing in it and put the juice on a non timing setting if you get gain anything?ive read the timing tunes for the predator are much stronger than the non ones.mite be stronger than the juice timing.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
- duallydave
like... what kind of hp and torque we talking?duallydave wrote:ive read that the predator with the rkl and a quad race box{with timing removed}netted some crazy hp.i think the quad box is stronger than the juice.what does the dr oerformance thing do?
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
- duallydave
I did the 573 with custom 200hp tune, XZT and VA on 70hp. Right now I'm just running ExtremeRKL Puff and nothing else and it's stronger than the 573, so I'm assuming I'm over 600hp and still have the VA which can give me another 100hp at the wheels apprx. Mork, try the RKL stuff... It's radically stronger than the 200hp custom tune, in my case anyway...
I will,, another question I have is, if I run with the regular tunes is that more pressure? Is that basically all the difference between the normal tunes and the rkl tunes?
As of so far I was running the custom extreme stacker tune that Johan wrote for me last year, along with my hot juice. I have a issue with not enough pressure, even with my modded cp3
Kevin
Kevin
