johan take a look, srt backfire
streetsteve
this is a log of my 05 srt-4 doing the backfire at wot, after the backfire the boost drops to 15psi until i reset my computer, some on srtforums say its overboost protection cutting the ignition, its pretty violent, also after this happens i cant control the boost, i can rise it 20 percent without the boost going up. if i disconnect the battery and reconnect it i can control boost until i get the backfire again.
streetsteve
RE: johan take a look, srt backfire
see anything out of the ordinary
this is using the toon_3 file?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
streetsteve
yea the last tune you adjusted for me, the check engine light went away but still getting the ignition cut, then no more boost control until i reset the computer
I think i see what is causing it, check your inbox...
Diablosport INC
Diablosport INC
streetsteve
i sent you a log of the toon you made for me, backfire is gone and boost dropped after cruising around town
